I just bought a Epson Artisan 700 All-in-One, and the problem I have is getting it set up. I've moved the transportation lock and when I turn it on it says to install the ink, the it quickly says its closing the CD/DVD tray and the it goes right to an error message tellling me to turn the printer on then off and view my documentation. I've done this and it keeps giving me that error message. What now?
  • jlubin Feb 18, 2009
    I have the same problem with an Artisan. I sent an email to their support group via their webpage at 9:16 AM...I've been trying to get through to their support line via phone (since no response to the email other than confirmation) and after being on hold for 9 minutes the first time, I was disconnected. I just redialed, was told there was a 5 minute hold time, but I'm holding for 10+ minutes now....a little concerned since the musak stopped and no more messages about "your call is important".
    I've reloaded software, re-installed inkjet cartridges, done everything they say in the internet & printed documentation and yet I can't get through the basic installation process....
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
dana_eng
  • 41 Answers
SOURCE: paper jam
try to fix with proper in place the roller .
Posted on Jan 12, 2009
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Posted on Feb 27, 2009
sherlyn c
  • 134 Answers
SOURCE: trying to scan to email on Epson Artisan 800
If you are scanning wirelessly, you have to launch the epson scan software from your computer and scan to e-mail from there. You can scan using either professional or home mode.
Please take note that scanning from the printer only supports direct connection, which means you have to plug in the printer to your computer via a usb cable.
If you cannot launch epson scan, please let me know. And include the operating system that you are using too.
Posted on May 03, 2009
aicaxz
  • 511 Answers
SOURCE: Epson Stylus Photo R200 will not accept DVD tray
Have you select the media in printer setup?
Posted on Jun 14, 2009
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
What printers will take espon ink cartridges 99
The products that uses the T099 ink cartridges are the following:
  • Artisan 700
  • Artisan 710
  • Artisan 725
  • Artisan 730
  • Artisan 800
  • Artisan 810
  • Artisan 835
  • Artisan 837
Sep 07, 2014 | Epson Office Equipment & Supplies
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My Artisan 700 will only print the top about 1 inch of each page. I've re-installed the drivers and software but get the same results.
The internal memory included in the printer maybe damaged.
Maybe the image you try to print is too big and the memory of the printer does not admise this size of files.
Thanks.
Dec 13, 2010 | Epson Artisan 700 InkJet Printer
My epson Artisan 700 have error ( paper is jammed in the product)
If you mean it comes up with a paper is jammed in the product error message when turned on, AND you have confirmed that there is no paper anywhere to be found inside the product, then you most likely have a defective sensor or electronic problem inside the unit that is not economically feasible to repair. Epson's web site is not at all helpful for this problem.
Sep 14, 2010 | Epson Artisan 700 InkJet Printer
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 16, 2010 | Epson Artisan 700 InkJet Printer
Can i scan pictures through my epson PM-A700 printer?
You need to download the Epson Scan software from Epson support web page http://www.epson.com (sorry, I cannot give you a direct link to the software since Epson uses session encoding in the URL).
The official name of your device is "Epson Artisan 700 All-In-One Printer", I assume.
With Epson Scan installed on your PC,any TWAIN compatible application should be able to use the scanner.
Feb 09, 2010 | Epson Artisan 800 All-In-One InkJet...
On epson artisan 800, turn on and starts but after 10 seconds it says scanner error and says turn off and restart,... does this every time and never stays on.
From what I've seen so far on the web (and what the user guide tells me) the printer needs to be repaired. I've got the same problem w/an Artisan 700 that has had ***very*** light use.
Jan 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
98 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
