Question about Honeywell Programmable Thermostat Heater
Honeywell heating system
I have a honeywell heating system with a thermostat model number of RTH2308.
We have tried everything. But the heater won't heat and the fan will not turn off. I have a call out to my home warranty company but until then I would just like to turn it off since it is only blowing cool air throughout my house. We think the heating element is not working.
Can you help me?
Linda
  • 2 more comments
  • yatesmeister Jan 05, 2009
    Where is the fuse located on my programmable Honeywell Thermostat T8011R ? and do you know what the E and F mean on the back ???
  • Anonymous Jan 12, 2009
    I have the same problem with my honeywell heating system thermostat model number RTH2308. The heater won't heat and the fan will not turn off. It is only blowing cool air.
    I called the Gas Company who stated that the burners are working properly but does not stay on. For some reason the burners shut off after approximately 2 minutes and the fan continues to run.
  • Anonymous Jan 27, 2009
    My thermostat is displaying correct information but the heat does not stay on.
  • csteele79 Jan 29, 2009
    my honeywell thermostat is not working, there is no heat coming in at all
  • 96 Answers
Go to the main power box and find the either breaker or fuse that runs the system and turn it off
Posted on Dec 25, 2008
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Trouble shoot rth2308
on pages 26 and 27 of the manual it clearly states that the unit has a safety device installed in at the doesn't allow the heat and the air to be turned on one right behind the otherif you are testing out both air and heat expect about a 15 minute delay between both of them that is to protect your system just leave the unit alone you don't update by itself and it'll start working correctly in about an hour
Feb 23, 2015 | Honeywell Programmable Thermostat Heater
All electric new home. Bought honeywell programable thermostat RTH2308. A/C works but heat will not turn on. This model # is not on their web site.
check to make sure there is a jumper wire on the subase between "rc" and "rh". these designations stand for red/cooling and red/heating.they are used independently if the system has a separate control transformer for heating and a separate one for cooling. they need to be jumpered when one transformer is used to control both modes. your fan "on" switch won't work the fan continuosly if there is no connection to the "r/c" trminal.
on the back of the thermostat there should be a switch you need to select for gas or electric heat. or there are small micro switches that need to be set for your particular application.check your installation papers for details.
these thermostats usually cover a wide range of applications and need to be selected.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Gas heater short cycles
At your indoor unit, look at 1 of the front panels and see if there is a clear, plastic view port. Look through it and try to see a red flashing led. Count the flashes and look at the factory data on the front of the unit. That should give us a trouble code and lead us in the right direction. Also make sure air filters are clean.
Aug 25, 2017 | Honeywell Electronic Programmable...
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
My Heating system
Can you provide me with a make of the furnace and a model number if possible. They will be found on the heating system cabinet inside the unit, not on the thermostat.
Jan 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
473 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
