...when black ribbon installed and I have changed the ribbon type in printer and the ribbon is installed in the same way as the colour ribbon that does work fine.
SOURCE: My Evolis Pebble 3 ink ribbon breaks after I print
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
SOURCE: My ink ribbon breaks after
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
I'm changing the ribbon type by opening devices and printers, right clicking on the evolis pebble 4 and clicking printer properties. I'm then going to graphics and changing it from 5 panel YMCKO to a black ribbon. and I still have the same issue. I don't think its a card thing as its not a manual feed, theres cards in there and it feeds in fine when the colour ribbon is in and prints perfectly with colour. Do I have to use manual feed when printing with the black ribbon of something?
ran a cleaning card through it and still won't accept the black ribbon.
I'm running Windows 7 Enterprise SP1 X64 and pebble version 10.10.28.3 if that helps anyone
