Question about Sony BDP-S300 Blu-Ray Disc Player
RESOLUTION IS FUZZY
I HAVE RECENTLY BOUGHT A PS3, AND WE PURCHASED A HDMI CABLE. OUR TV IS EQUIPPED WITH 1080P. THE FIRST AND ONLY DISC WE TRIED WAS THE LOST BOYS THE TRIBE.SOME PARTS OF THE MOVIE PLAY GOOD, BUT OTHERS ARE VERY FUZZY. IT SEEMS THAT I HAVE TRIED EVERYTHING. IF YOU HAVE ANY ADVICE I WOULD APRECCIATE IT. THANK YOU
  • 126 Answers
Get a refund. This fault is a can of worms mate. A road you do not want to go down
Posted on Dec 25, 2008
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I have audio but no video with my HDMI connection
You may have the resolution on the PS3 set higher (say 1080p) then what your TV supports (1080i or 720p). Use the Yellow/Red/White cable that came with the PS3 to connect to the TV. Go to that input and check the resolution. Start at a lower resolution and check the HDMI input. If the TV does support 1080p, try a different/better HDMI cable.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
While playing MGS4, or watching DVDs in my PS3, the lower half of my LCD TV is a shade greyer than the upper half. I am running 1080p through an hdmi to my vizio 32" lcd tv that is full 1080p compatible.
Hi:
1) have you tried using another hdmi cable?
2) are you sure that both ends of the hdmi cable are firmly fitted, such that there is no strain on the cable?
3) have you set the resolution to 'only 1080p'? i.e. make sure 720p and 1080i are unticked, in the Display Settings section, under System Settings in the XMB
Hope this helps,
Please leave feedback if everything is working.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
1080p high def issues
The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
Mar 29, 2008 | Televison & Video
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony BDP-S300 Blu-Ray Disc Player Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
