Question about Microsoft Windows 98 for PC
Divide Overflow Error msg
To play an old DOS game that i knew would show this msg on ANY Pentium grade cpu, i recently got hold of and old DOS and windows 3.1 computer .
it is an intell DX266Mhz cpu
i thought for sure i had a winner.
puter works, installed the game... seemed to install
tried to play, and there was this error msg
Divide Overflow
any suggestions?
old game obsessed
Well, in DOS the game Wizardy - Bane , still shows up the divide error msg
how ever, i decided to try to run the game in windows 3.11
and it worked!
i am happy.
so, this really wasnt a true fix, but more of a work around
Posted on Dec 26, 2008
NTVDM CPU has encountered an illegal instruction. CS:0000 IP
One reason this could happen is that you are trying to run an old DOS based, or simply an old incompatible, program. These are usually old games. If this error only happens when running old games written for an older operating system, the only solution is to get an updated version.
Sep 21, 2012 | MSI L1350430US Netbook
Recently, when I play graphics intensive games like devil may cry 4, or resident evil 4, the screen suddenly turns black(and becomes unresponsive(need to manually restart the pc)) or it show the blue...
Hello.
Looking at your specs, I assume that a Pentium 4 is not enough to run these kinds of games, so the overwhelming amount of data going through the cpu may have been causing your system to overheat.
Do these steps:
(1) Uninstall and then re-install your graphics card driver, if problem persists, go to number 2
(2) Try playing around with the ATI Catalyst settings, set everything there to default
(3) If problem still persists, then I -am- sure that your PC and/or graphics card is way too overheated, in this case:
(a) I recommend getting a heat-monitor (doesn't come cheap though) for your PC, to keep yourself notified of the temperatures of your PC
(b) Try buying more fans and if you can afford it get a water-cooling system
Above all, if you can afford a better -Gaming- PC then I'd suggest that, because your system isn't really that great for new games.
Nov 23, 2010 | ATI RADEON X1650 Graphic Card
Mother board is ak77 pro 133 vt8233 will not run xp proI
The BSOD (blue screen of death) usually means that a computer component has failed. This could be a hard disc drive, a memory module, the cpu, or the motherboard. I would start by checking out the hard drive first. See if it is spinning and not making any clicking sounds. Try replacing it if you have another one. Then check memory and cpu. Some people actually like having an old computer hanging around. They install Windows 98 in it so they can play old dos games and games that don't require a blazing fast processor! Good luck...Hank
Jan 09, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Borderlands Pc Game not running. Please help.
Get the latest video drivers. Also you are short of 600 MHz to meet the CPU requirement
Nov 29, 2009 | Dell Vostro 1500 Notebook
16 bit error while using turbo c graphics...........
Try running Turbo C with administrative priviliges and running it as Windows XP SP2 if you have Vista. Seems to work for me.
Aug 04, 2009 | AMD Sempron LE-1300, 2.3 GHz...
Lp 5 error
Try This:
http://www.skerryvoresoftware.com/SimplyCalenders/faq_G22.php
Feb 16, 2009 | Computers & Internet
Frogger for Windows 97
As far as I know, the music does not play on a SATA drive, or on a NT based operating system. It seems to only run on the DOS based operating system, like Win 95, 98, 98SE, and ME. Frogger works fine (with music) on my older Pentium 4 with Win 98SE.
Nov 07, 2008 | Video Game Consoles & Games
When i try to play the game i get fatal error msg
The error message means that your video card "ATI Visontek Radeon 9250" does not meet the game requirements.
Your video card Pixel Shader Version is 1.4 , and Devil May Cry 4 needs at least Pixel Shader 3.0 or higher support.
To play the game you need to upgrade your video card, to meet the minimum requirements for the game you need a video card like the ATI Radeon X700 or the Nvidia GeForce 6600.
The requirements list for the game as available in the "ReadMe" file for the game Devil May Cry 4 is mentioned below.
System Requirements
Operating System: Microsoft(R) Windows(R) XP *1, Microsoft(R) Windows Vista(TM) *1
-CPU: Intel(R) Pentium(R) 4 processor supporting HT Technology or higher
(Recommended: Intel(R) Core(TM)2 Duo processor or higher)
-Main Memory: Windows(R) XP : at least 512MB (Recommended: at least 1GB)
Windows Vista(TM) : at least 1GB (Recommended: at least 2GB)
-Video Card: DirectX(R)9.0c/Shader3.0 compatible, VRAM256MB,
NVIDIA(R) GeForce(R) 6600 series or higher
*excluding NVIDIA(R) GeForce(R) 7300 series
(Recommended: NVIDIA(R) GeForce(R) 8600 series or higher)
-Sound Card: DirectX(R)9.0c compatible sound cards
-DVD-ROM Drive: DVD9 compatible drive
-Monitor: 640x480 (VGA) or higher (Recommended: 1280x720 or higher)
-Input Devices: Mouse & Keyboard required (Recommended: Xbox 360(R) Controller for Windows(R))
-Hard Disk Space: at least 8GB
Oct 25, 2008 | Capcom Devil May Cry 4
Divide overflow error,
if the start menu click run and enter msconfig
Click on startup and turn off all the programs
Click on Servics and turn on hide all microsoft services
Turn off all other services that are not from microsoft
restart your system
you will see the error has gone
one by one turn back on service and start up programs and restart after ever turn on to isolate which program causes the error
YOu can then leave that turned odd and turn the rest back on.
Jan 09, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
201 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
