Question about Jet 7 Portable Power Chair
Jet7 directional control not working
Everything working, except the hand control..help. Have checked battries, wiring, and connections..
  • 32 Answers
We sell refurbished joysticks contact us
Posted on Apr 03, 2009
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 | Pool & Spa
VF T8500 treadmill. Everything works except the belt...have combed through other replies on here..how do I check the brushes?
I am not familiar with this model, but usually, when you see red LED light up on the control board, is a sign of a malfunctioning board. You can check if your motor works but putting a 35A rectifier bridge at a 110VAC power source and connect the motor. Motors are usually 180VDC. So if it moves, it's OK. If it does, you should also place your hand on it to see if the operation is smooth. The brushes sometimes are under a rectangular plastic part on the opposite side of the small belt, or under a black round screw-like plastic. 21ccd37b-fec8-406d-bd2f-a1ea7fd624fa.png
Jan 20, 2014 | Radio Communications
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 09, 2012 | Kenmore Dishwashers
Hi, I wanted to start my Jaguar S typ, but the battry which is in the luggage compartment is dead & it is not possible to oppen it by key, but a buuten which is not working because of battry. How can I...
hi.
it is a little awkward but it can be done.
if you go under the car with jump leads, connect the positive lead to the thick wire on the starter motor. connect the negative to the body or chassis.
the starter lead is connected direct to the battery so it will give enough power for you to open the boot using the button or the remote.
hope this helps
Apr 02, 2011 | 2000 Jaguar S-Type
I have a Hampton Bay Altura ceiling fan with light and remote control. Everything seems to work properly except that the fan will not start turning on its own it just hums. If I help it to begin turning...
sounds like the motor is going bad, you may be able to take it down and take it apart and clean it up. The armature is what usually goes bad, you will need to do some price checking, new motor versus repair bill. Hope this helps Tim
Dec 02, 2010 | Hampton Bay Heating & Cooling
TRITON #PL3-01 HAS NEW BATTRIES, BUT WILL NOT MOVE WHEN HAND CONTROL IS ACTIVATED. WHERE MIGHT PROBLEM EXIST.
mcdevito75 here, Most likely at the battery connection, are the battery--ies fully charged?? check connections at battery, and motor.
Jun 23, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
MICROPHONE NOT WORKING EVENTHOUGH IT IS INSTALLED
If you have a webcam with a built in mic you need to make it your 'default' (The one you want to use)
Set up Audio
Laptop x webcam/mic x Vista x Yahoo Messenger
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Sep 29, 2009 | Logitech Webcam
Won't play with lights on
You probably have the ground wire hooked to the illumination wire for the car. it will act as a ground when the lights are turned off
Dec 24, 2008 | Car Audio & Video
Jet 7 Portable Power Chair  Logo
80 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
