Multifuel stoves can accommodate various fuels including
white gas, unleaded auto gasoline, kerosene, jet fuel and diesel. They tend to
cost more than any other camping stove.
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves Nov 25, 2010 - 25 posts - ā6 authors
The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
How to light a wood stove fire Stove Help & Advice Home
There are many ways to light a fire in a wood stove. There is no one right way to do it and I am sure that all the stove owners out there will have their own individual ways of lighting fires that have developed over the years.
This is one way to light a woodburner. Ensure that the stove firebox is not full of ash - remove ash if necessary using a suitable metal container. If the stove is a multifuel stove where the only air supply is from beneath the stove grate then you will need to make sure that the grate is clear from ash and that the ashpan is empty (or at least that the ash in the ashpan is not obstructing the air flow to the fire).
Open the bottom air vents of the stove and open the flue damper if you have one. Some people use firelighters but personally I think that they smell bad and are uneccessary.
Start with some pieces of newspaper and scrunch them into loose balls. Some people tie them into knots or other shapes which is fine as well. I have tried this and it takes much longer than just scrunching the paper into balls. I use about 8 full sheets of newspaper to light the fire. It is possible to use much less paper, but if there is no need to conserve your newspaper supply then my opinion is that you might as well be assured that the fire will light by using a little bit extra. Pile the balls of newspaper in the centre of the firebox. Get some kindling. If you do not have some already prepared then use dry seasoned pieces of firewood. Softwoods or light hardwoods are best so pine, beech, or ash would be fine. Use a hatchet to chop the wood into some small pieces roughly 10mm square. The sizes do not have to be very precise and I would not recommend measuring each bit! Lay around 6 small pieces on top of the newspaper in different directions - rather like the game pickup sticks. The idea is that air and flames should be able to get to each piece of wood. Now lay a few larger 30mm and 40mm square pieces on top.
Light the newspaper in a couple of places at the bottom and when they are going close the door of the stove.
Once the wood has caught alight and the fire is going well inside the stove you can put some larger pieces of wood into the firebox. Place them gently on top of the fire. Do not fill the firebox with wood - I would recommend burning around 3-4 large pieces of wood at a time. At this stage you can turn the air supply down a little but aim to maintain good flames whilst not letting the fire smoulder.
If you have air vents at the top of the stove then close down the air vents at the bottom and open those at the top. You may need to do this gradually as the fire develops.
A novel way of lighting a fire is in a top-down direction. You start with the bigger pieces of wood, then on top of them put the smaller pieces of kindling and on top of that lay some newspaper balls. Everything is done in the same way as in the bottom-up method discussed above but just in reverse order. Light the newspaper and the fire will work it's way down. Surprisingly this is a remarkably good way of lighting a fire - why not give it a try.
If you are still having troubles lighting your fire, you can always purchase a Phoenix firelighter. No newspaper or kindling is required and can have your stove roaring away in 2 minutes. The Phoenix Firelighter has revolutionised lighting of solid fuel fires whether it be wood for coal and only costs 1p per fire.
Things not to do
Do not use paraffin, ethanol, petrol or similar to help you light a stove. Here is an article about someone who did Do not leave the stove unattended whilst it is being lit, especially if you have cracked the door or ash pan open to give it that little boost of air.
That clicking and knocking noise you hear is called cavitation. It's when the bubbles of steam are cooled down rapidly and implode upon themselves. Cavitation is not a good thing to have in a boiler as it can cause dramas. This cavitation is more than likely because the boiler is firing too hot. A service technician should be called to turn the regulator down a little bit.
