Question about HP Pavilion a6460t Notebook
Can I use 800MHz or more memory in my laptop
Laptop HP Pavilion dv6000. Now I use 1GB (2x 512GB) DDR2-667MHz, PC2-5300. But I want improve to 2 GB. I don't know if I can use more speed like 800 or 1066MHz.
Thanks.
    Sergeant:
  • 279 Answers
FYI, for major manufacturers like HP or Dell, you can just go to www.crucial.com and use the Memory Configurator to find out what kind of RAM your PC uses and needs. Further, they link to the RAM you need after testing so you can just buy it there if you want.
BTW, you don't say what OS you are using. If you're using XP x32 or Vista x32, Windows won't see more than 3 - 3.25 GB of that RAM if you get 4 GB. To be able to use the rest, you'll need to make sure your OS is x64.
Posted on Dec 25, 2008
  • 59 Answers
No, i strongly suggest to get the 4GB (2gbx 2) memory , since the memory is so cheap now, go www.newegg.com check out the price, and no get the 1066mhz, becasue this is for new computer.....................
you must get the 800mhz or lower, otherwise you have have some side effect for 1099mhz memory card........
Toshiba Satellite L305D-S5882 has two RAM ports for 1GB &2 GB DDR2 800MHZ, one got spoiled, am now using 2GB RAM, can this single port operate with 4GB RAM?
Unfortunately, the slots on this motherboard are limited to a max of 2 GB each. You won't be able to use a 4 GB DDR2 800MHz memory stick with this computer. (This limit is due to the way the circuitry/programming of the board was designed.)
I wish that I had better news for you. You might be better off installing a Unix based OS which uses less memory or searching for a new laptop. Just remember to save your files on a different drive before making any changes.
Jan 30, 2012 | Toshiba Computers & Internet
Have an HP Pavilion ze4935wm laptop. Want to upgrade to higher GB and RPM. What is the highest I can go with this type of laptop?
This is an older laptop that uses a PATA (sometime called EIDE or ATA-100) drive.
The largest drives commonly available in PATA type for laptops are 320GB, at 5400 RPM.
There are bigger and faster laptop drives, but they will not work with that laptop since the bigger drives require a SATA interface.
PATA drives are more expensive than their SATA equivalents, it might be better to invest your upgrade dollars into a newer laptop.
Apr 17, 2011 | HP Pavilion ze4935wm PC Notebook
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
Have 512MB RAM. Was told to max it out because the machine is extremely slow. Has two slots with 256MB. Can I put two 512MB memory modules in those slot to increase 1G or RAM?
yes, after looking up your laptop on hp's website, I have determined the kind of memory you need; (assuming your computer is the one you put in the question, HP Pavilion ze4805us Notebook PC)
you need 2x 512 mb, 200-pin, DDR 266 memory
I looked and found some Corsair (highly respected company in computer memory) memory, for 22.99 for each DIMM (you'll need to buy 2); see link below.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145482&cm_re=ddr_sdram-_-20-145-482-_-Product
If you have any more questions, please let me know!
Thanks,
Mike
May 16, 2010 | HP Pavilion Ze4805us Notebook
Upgraded my p35-S6292 laptop from 512gb to (2) 1GB
make sure that the two memory module have the same speed. say for example. if the first memory has a 667mhz speed the other memory should also be 667mhz. different memory speeds will cause conflicts.
Apr 27, 2010 | Computers & Internet
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
Install Ram upgrade for HP Laptop Pavilion
Maximum memory capacity is Up to 1 GB (1024 MB) SDRAM using 512-MB modules.
Mar 27, 2009 | Computers & Internet
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
HP Pavilion a6460t Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
