Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Attaching starter rope to pulley
My neighbor says that the starter rope was installed wrong at the factory. We installed the rope his way and the rope came out on the first crank. Now I had to buy a new pulley and I need a diagram to show the correct way to attach rope to pulley.
This is on a Weedeater Blower (gas) FL1500. Thank You
  • tony75163 Dec 30, 2008
    Thank You very much for your answer, however this model uses a screw instead of a knot to hold the starter rope in place. The starter rope was also looped around the starter pully shaft to prevent the rope from pulling loose from the hold down screw. This is where the problem began, my neighbor took it apart and I don't remember how it was looped around the shaft. The neighbor said it was all wrong from the factory but it worked for five years. The only problem I had was that the rope didn't recoil very good the last year or so.
  • Anonymous Mar 23, 2009
    where would one find the starter assembly?
The factory method is to bring the pull cord through the hole on the outside of the pulley, wrap clockwise once around the cogged part of the pulley, then over the pull cord and a clockwise wrap under the screw with the searated washer.
Posted on May 28, 2009
  • 163 Answers
Hi. sorry it took me so long to answer you. this is the easiest way to replace the starter rope:
first remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. then feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt it a little and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, i suggest replacing the whole starter assembly because the coil spring is extremely difficult to replace by itself. thanks for using fixya.com. if you have any other qestions or need further assistance, just let me know and i'll be happy you. happy holidays
Posted on Dec 28, 2008
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
Installed new starter rope on 3.5 briggs and stratton mower and when you pull rope to start, rope does not recoil
The spring must be tightened when installing the cord:
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Mar 18, 2011 | Briggs & Stratton Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
I have an MTD Snow Thrower Model 2M1 with a broken starter rope. I replaced the rope but cannot get it to rewind the rope after I pull it. What am I missing when I reinstall the rope and spool?
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Dec 01, 2010 | Mtd Products Yard Machines 158CC Tiller
Broken starter cord on briggs and stratton quantum 40 roughly 1994 how to repair
Remove the recoil. Sometimes depending up on model this required complete air shroud removal. Remove the parts of the old rope. Remove the rope fro the rope handle. NOTE the knot in the handle. Brun both ends of the nylon rope with a match and pinch the burned end into as small of circumference as possible. Install new rope into the starter handle and tie the knot. Pull the new rope into the handle until it seats securely.
Prewind the recoil pulley as far as you can easily wind it. Back it off (unwind) just until the rope guide and pulley knot hole are aligned. Then either c-clamp it in place with the rope knot hole aligned with the rope guide hole or have a 2nd person hold it the pretensioned spring and pulley in position. Thread the rope through the rope guide and on into the pulley knot hole. (takes some effort to get it aligned and through the knot hole!) Pull the new rope through the knot hole and tie 1 knot. Pull starter rope and fit knot into pulley knot hole. Release pulley C-clamp or have helper let go of pulley. Rope should rewind into the recoil.
Reinstall recoil / air shroud. Happy mowing!
Thanks for choosing FixYa.
Kelly
Nov 20, 2010 | Briggs & Stratton Garden
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
Ryobi string trimmer RY34420 has a non retracting pull cord. How do I fix it?
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Aug 31, 2010 | Ryobi Garden
Bought a new part to hold the starter cord for my tiller
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope through from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 01, 2009 | Troy-Bilt Garden
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
931 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
