Question about Lucien Piccard 26024 Wrist Watch
Need to adjust a Lucien Piccard watch band 27097BUD
Just received this watch for Christmas and need to know how to make the band smaller without taking a drive to the nearest "authorized dealer." It is the Lucien Piccard "Soulmate" watch, serial number 27097BUD.
escapement
  • 2334 Answers
SOURCE: Add links to a Lucien Piccard 26006SS
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
escapement
  • 2334 Answers
SOURCE: how do i remove links from a ceramic lucien
Browse through my Tips and Tricks. There you will find how to add or remove links.
Posted on Feb 25, 2011
VOTIT
  • 2071 Answers
SOURCE: Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Posted on Jun 14, 2008
SOURCE: lucien piccard watch
The arrows you are seeing are for sizing the band. I cannot find 26311SS in my data base, but I have a good idea what you need to do. The curved piece is a safty that goes over the clasp. Take something like a round toothpick and with the curved piece going to the right like this: ( put the toothpick under the far lefthand side, in the middle and see if you can pry it up ,( I say use a tooth pick so not to scratch up your watch) it should flip over to the right.Check and see if there are any spring loaded buttons on either side of the clasp, if there is push them in ,and lift to your left If there is no buttons just pry up towards your left. If this dosn't work PLEASE let me know, and I will find the exact watch and we can go from there. Good luck!!
Posted on Oct 28, 2008
  • 2501 Answers
SOURCE: Lucien Piccard 27094bk manual
Go to the web site "lucienpiccardusa.com/"
From the menu on the left select "customer care".
Scroll down the page until you find "instruction downloads"
Choose "three stage movement instructs"
If this is not quite what you need, you could email them.
Posted on Jan 07, 2010
I received a lucien piccard vd53 watch and can't get it to run.What do I do to start it??
I see your watch has a Seiko VD53 Quartz Chronograph Movement. Several possibilities come to mind - the watch may have a small plastic spacer under the crown which is there to stop the battery running flat before the watch is sold. If that's the case then simply remove the spacer and press the crown in. Possibly, the battery is flat and will need replacing, or you've received a faulty watch - either way (and I interpret your using the word 'received' as meaning that it was a gift to you) you should tactfully point this out to the giver. They wouldn't want to have wasted their money, and hopefully they've kept the receipt.
Nov 13, 2017 | Lucien Piccard Watches
Looking for a leather band for a lucien piccard
i only found some for women sorry !!! http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
Nov 09, 2010 | Lucien Piccard 26024 Wrist Watch
We have a lp27003tt piccard watch. how do we remove a link in the band?
I dont know what kind of band that is, but the link following shows you how to do several of the basic pin-push style that most watches are.
http://www.webwatches.co.uk/how_to.htm
Aug 21, 2010 | Lucien Piccard 26024 Wrist Watch
How do you get the Lucien Piccard Automatic 26570SL running?
You have to wind the watch before it will run. The watch will also need to be re-wound every 24-48 hours.
Jan 05, 2009 | Lucien Piccard 26024 Wrist Watch
Lucien piccard watch
Oct 25, 2008 | Lucien Piccard 26024 Wrist Watch
Need New Watch Band
Jun 14, 2008 | Lucien Piccard Watches
Lucien Piccard 26024 Wrist Watch Logo
1,628 people viewed this question
Top Lucien Piccard Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
