Sport & Outdoor - Others Logo
Anonymous Posted on Sep 10, 2012
What could be the cause for a broken gear on my aircraft?
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Sep 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
34
Helped
7778
Points
82
There are two main reasons why the gear is broken. One is when the engine kicks back which can cause fractures in the starter drive gear. Second is when the engine retracts and extends in an unusual way.
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Jul 09, 2012
SOURCE: I have a broken gear on my aircraft starter, what could be the causes?
In some cases engine kickback will fracture starter drive gears. Kick back is related to engine set upand can be anything from incorrect timing to problems with the fuel system.
tip
Learn About an Aircraft, Part 3
, ://i.fixya.nethttp://i.fixya.net25650279-w123deulyqo0pc5nhlq3ghvj-3-0.jpg">
  • Straight and Level Cruise:
Start by setting the RPM to a cruise setting of 2200 RPM, using the throttle. This should give us a cruise speed of about 108 Knots.
Use the yoke to maintain level flight by keeping the small aircraft symbol level and exactly on the "Artificial Horizon" line of the six pack . Keep scanning the rest of the six pack to help maintain level flight. Scanning the six pack will show if you are going straight or turning, climbing or descending or if the airspeed or altitude starts to change. Always use small corrections to the aircraft's attitudes and wait to see the response.
  • Climbing Phase:
We will climb by increasing the throttle to full throttle. Now you can pull back on the yoke to raise the aircraft nose to about ten degrees above the horizon. Now set your climb speed (using the yoke), by changing this 10 degree climb, until you have an airspeed of about 80 knots. meanwhile continuing to scan the six pack at all times and make sure that nothing is changing that you don't want to change. Scanning the six pack will show if you are going straight or turning. or if the airspeed starts to change.
This Aircraft will stall (in a turn) at approximately 53 knots (no flaps) so keep your turns shallow and avoid any speed below 75 knots to allow yourself a margin of safety. Always use small corrections to the aircraft's attitudes and stay well out of any limit zones that are indicated on the instruments.
  • Descent Phase:
A descent to a lower altitude is done by reducing the throttle to an engine speed of about 1500 RPM while setting the air/fuel mixture at full rich (red knob fully inward). If you intend to be descending a long time at low engine power, then you should use carburetor heat to prevent icing. At reduced RPM, the engine will not be producing as much heat so we may have to put on the carburetor heat, or you can occasionally increase the engine speed for a minute to gain some heat and clear the engine.
I have downloaded Microsoft 737 Professional after downloading Microsoft Flight Simulator X (required in order to use Microsoft 737 Professional -
May look in AVG quarantine and see if any of the &#& is in there. You can have AVG disregard certain folders that it may think are virus's.
What can happen if I didn't insert the gear all the way?
If the gear is not inserted all the way, stress will be placed on the drive gear which will rapidly wear the gear or fracture it.
1helpful
2answers
Could the resistance to the starter be the reason that my starter is starting slow?
Jessy is correct, but there are a number of other points to note.
You didn\'t mention the aircraft type nor engine type, so I can\'t be too specific. The location of the battery is important; some aircraft have the battery in the back, some under a seat and some in the engine bay. The distance from the battery will have an effect on the starter. Earlier aircraft types have been known to have aluminium battery cables. If they are fitted on your aircraft you should change them to copper. (Most copper cables will be \'tinned\' so they will look silver, don\'t confuse them with aluminium). The engine is mounted with rubber mounting blocks, there should be a large earth strap or cable fixed to the engine from a \'ground\' point on the aircraft or engine mount. This earth lead is very important and should be very well secured. If it is not the starter will find an earth through other electrical leads such as the \'screening\' around the magneto switch leads or the alternator field leads. This can cause a fire. What I normally do is to take each earth lead and secure it using a \'shakeproof\' or \'star\' type locking washer between the lead head and the engine or airframe ground point, (like a sandwich). This helps to make a sound connection. The live leads should not be overlooked either, nor the condition of the battery and the battery terminals. Lastly, some of the smaller aircraft engines were plagued with bad starting due to the fact that the starter turned the engine too fast and the magneto impulse coupling retracted so not allowing the impulse to catch on the impulse pawl, thus the ignition was not retarded nor was the impulse \'wound up\' to give a good spark. The solution to this problem was to fit starters with a different gearing that slowed down the cranking speed. There is a Lycoming service letter on this subject. So, check that you have the correct starter fitted to the engine type - not all starters are the same!
What are the advantages of aircraft grade arrows?
Aircraft grade arrows are made of aluminum and are lighter as well as cheaper than other arrow therefore they are much faster and accurate.
Aircraft unpressurizes at 10000 ft. what is the cause?
if it were a real aircraft and not a model Delta Connection Skywest Crj-200, broken cabin pressure dump valve.
Top Champion Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Champion Sport and Outdoor - Other Expert? Answer questions, earn points and help others
