Question about Ovens
Bottom of gas oven will not work - Ovens
    Sergeant:
    Champion:
  • 338 Answers
Replace ignitor
Posted on Dec 25, 2008
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Gas oven not working. burners work. not
The holes may be plugged with residue. With the oven off! Try taking a paper clip and unplugging the whole. Make sure the ignitor next to the burner tube is secured and is not broken. These are under the bottom oven plate. Most models.
Sep 04, 2009 | Maytag Ovens
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
yes replace the ignitor, this is the most common failures of ovens not coming on.
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
