Question about Compaq Evo D300 PC Desktop
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the monitor is green that time. just after 5-6 seconds that blue line also disappears from screen and screen becomes black. monitor led becomes orange. cpu beep sound and hard drive led is normal. pc was 100% ok last time when shut down. now i am trying to on after a gap of 2 months and this problem is coming. pl help
  • 37 Answers
Tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Posted on Dec 25, 2008
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Bright green vertical line down Compaq Presario C500
Sounds like the display is going out and may have to be replaced to solve the green line problem.
Oct 12, 2009 | Compaq Presario Notebook
Lcd lights got dimmer
First check to make sure the power adapter is connected to the laptop properly, if not it runs off the battery and the display is dimmer.
Second check the brightness setting, you can adjust the brightness by pressing the Fn key plus the F7 or F8 keys to adjust the brightness.
If this doesn't work then :-
The problem/fault could be one of several things. Could be the CCFL lamp, the inverter that supplies high voltage to the CCFL lamp or the video card.
The video card cannot be replaced on a laptop, it is part of the motherboard.
To determine if the video card is faulty, connect an external monitor to the external video port on the laptop, power up the monitor first and then the laptop. The video output will switch automatically to the external monitor, if you see a normal Windows image then the video card is OK.
Next, shut down the laptop, disconnect the monitor and power up the laptop. After the laptop boots up look at the LCD screen at a sharp angle and if you see a dim or dark image then the fault is a faulty CCFL lamp or inverter. Most likely the CCFL lamp is faulty, but the inverter is easier to replace.
Check out LCD Parts WEB site for service, parts and DIY info. Use this link.
www.lcdparts.net
Aug 11, 2009 | Compaq Presario M2000 Notebook
Monitor display is rotated 45 degrees. Can't get it back to normal.
right clik on the desktop and select graphic options then choose rotation. set to normal mode. fine ???
May 03, 2009 | HP Compaq Presario SR1110NX PC Desktop
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
PC DO NOT BOOT
It seems that you don't have any Operating System installed. You need some bootable OS setup disk, and change BIOS settings to boot you PC from CD. Insert disk and restart PC, then follow onscreen instructions to setup OS.
Jan 27, 2009 | Compaq Presario 5000 PC Desktop
When switched ON, my Compaq Presario Desktop PC, a very bright and sharp blue line appears on the screen of monitor for few seconds and then goes of. Further no display. CPU led are ok. bip sounds normal....
sounds like a new monitor is in order or try another one and adjust the display settings in case the monitor cant handle what you have it set at, but i suspect its a new monitor
Dec 19, 2008 | Computers & Internet
Monitor display not coming after some minutes
No it is your monitor after all you used your another monitor and all was well. For what its worth get another monitor. NOTHING ELSE IS WRONG!!!
Sep 29, 2007 | Compaq Presario 5000 PC Desktop
Compaq Evo D300 PC Desktop Logo
232 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
