Question about Panasonic SC-HT441 Theater System
All the circuit got burned for modle SA-VK 71D
Due to power fluction the hole board got burned (damaged), so we need ur solution Please sugest us what to do.
If not can i get the whole circuit board for replacement
Please replay as soon.
Thanking you,
manju
2 Suggested Answers
  • 12962 Answers
SOURCE: So I found out I need a circuit board for my panasonic sa-ht80.where can i get one from I tried everything. Please help
Guess you already tried ebay and the manufacturer.. But just keep checking because sooner or later it will appear. Today they had the entire receiver.
Did you check out the questionable circuit board for bad caps that are bulging or leaking? Burnt resistors? Diodes? U might get lucky.
U have nothing to lose and all to gain at this juncture.
Posted on Sep 16, 2015
My panasonic music system (SA VK-960) Is not working properly it shows (F61) error all the components are well attached with music system but there is still F61 error . Help us to resolve this error.
See page 40
Power Supply Error Code Table http://diagramasde.com/diagramas/otros2/panasonic_sa-vk960gc.pdf
Suggest checking power resistors in amp circuits for failed resistor. replace with identical rating in that the power resistors are used in the saftey circuits. Also check around these resistors for failed solder connection.
Hope this helps?
Jun 29, 2017 | Panasonic Audio Players & Recorders
Where i can get a remote for my Panansonic Dvd player SA-VK 81D
Either contact Panasonic to see if its available or
Google the model number with "remote" to try to locate one.
Jun 01, 2012 | Panasonic Televison & Video
My panasonic sa vk-480 having sound problem, i can hear from head set but no sound from speakers
probably the conection is loose or the cables from the amp to the speakers are loose or bad
Apr 17, 2012 | Audio Players & Recorders
Has anybody discovered the cause or solution to the c700 not charging batteries or running off the ac adapter.
The usual cause is that the power jack solder connections have broken loose from the motherboard. This is often the result of the power plug flexing, or pressure caused when people tip their laptops up to get a better look at the screen. Then no power gets from the adapter onto the board.
To repair this, you need to remove the motherboard to get access to the solder side. Often the connections can just be resoldered. Sometimes the circuit board tracks need to be repaired with jumper wires. And occasionally the damage is severe enough (burns due to heating from the bad connections) that the only fix is to replace the board.
If you're not very comfortable with soldering on printed circuit boards, take this to a computer service shop for the repair. It's possible to do more damage to the board in trying to fix this if it's not done correctly.
Mar 08, 2010 | Compaq Presario 700 470024-192 Notebook
I turn the tv and inside star a shortcut with smoke
Ur tv circuit board is burn or ur power board is dead. Make sure ur TV worth repairing it cost alot money for this prob.U know little about
Electronic u can check if there no burn in the circuit board check the plug go to the power u can buy that board in the net might work might not.Could burn alot of things in power surge.
Aug 12, 2009 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
I have etopn webcam 1.2 mega pixels i have lost the software cd how can i download it back
Please go below link search ur modle and then download tht driver... and ur web cam will start...
http://www.eton-sa.cn/download.asp
Thanks....
Jul 30, 2009 | Computers & Internet
Sony gr3. disc does not rotate
HELLO HORRIE ,
PLEASECHECK OUT FOR UR POWER CONNECTIONS AND CHECK OUT WHETHER IT GETS THE REQUIRED AMOUNT OF POWER IT NEEDED.
PLEASE CHECK FOR CONNECTIONS FROM POWER SUPPLY MAIN BOARD OF YOUR PLAYER TO MOTHER BOARD.
THE DRIVER IC OF CD ROTATOR MOTOR MIGHT NOT GET POWER DUE TO SOME BREAKS OR BLOWN OFFS IN THE CIRCUIT.
BEFORE YOU TAKE IT TO A TECHNICIAN PLEASE CHECK FOR THE ABOVE
Sep 24, 2008 | Sony Televison & Video
Panasonic SC-HT441 Theater System Logo
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
