Question about Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor
How tight should I put it on my wrist and should it give me one squeeze or several before releasing
  • 74 Answers
Up to about 160mm for average blood pressure-up to 210mm for elevated Blood pressure. As the pressure lets down it will squeeze several times as it calibrates itself. Hope this helps.
Posted on Dec 29, 2008
My watch only works when it is worn on wrist when it is off the wrist it stops i think the temperature of the body keeps it going and it is battery powered
Is it all digital (with a digital readout), or does it have two, or even three hands that point to the time?
May 12, 2017 | The Watches
What is the chain brake an where
not on the older chainsaws
newer ones it s normally the black lever you hold
Check the Chain Brake
Make sure the chain brake is working properly by putting the chainsaw on a stable surface. Release the chain brake, squeeze the throttle and then activate the chain brake by pushing your left wrist against the kick back protection without releasing the handle. This should cause the chain to stop rotating immediately.
source
http://www.tractorsupply.com/know-how_home-garden_outdoor-power-equipment_chainsaws_the-basics-of-using-a-chainsaw-for-beginners
can be part of the centrifical clutches
Apr 30, 2016 | Garden
Cannot remove drill piece from drill. Totally locked. how can I release bit to replace it.
Try putting it in reverse. Hold the chuck collar with left hand. With drill in low speed setting, squeeze trigger. If it won't release and tries to tear your wrist off, hold the chuck collar in a pipe wrench, workmate bench vise, or large water pump pliers.
In some circumstances there is no substitute for brute force.
Mar 16, 2015 | Dewalt 1/2" 18v Cordless Drill/driver Kit...
How to put in freon
First buy one of the Auto Pro Refrigerant units with coolant and guage together at an Auto Parts store. you must locate the" input valve on the cooling line..should have a nipple on it,that screws off . There are 2 but product and guage only fits one. Unscrew can from guage and remove safety tab.....RE_screw can back on too gage making sure it is tight enough to puncture can. 4 clocklike hands on guage,,set the smallest arrow to approximate outside air temp. Push end of refrigerant hookup connector onto imput "nipple".. start car,,turn A/C on max cool............pull trigger on refrigerent unit,,,,shake and roll can slightly...when you release trigger,the gauge will indicate how much you have charged it...if completly empty,it will take about one half can,before compressor cluch begins to turn...squeeze release....squeeze,,release until pressure had indicate charged.
Jun 07, 2012 | 1997 Chevrolet Lumina
How to bleed the back berak. Its not working and travels to the bottom and no resistance
hi there...... their should be a wee nipple or an 8mm nut on the caliper the best way to bleed from the caliper is to open this ........while it is open squeeze the break then close it finger tight is enough and release the brake then pump again may take several attempts to get it right but should work handy enough but the ..... IMPORTANT thing is time the the opening of the nipple and the squeeze of the break so open nipple then squeeze fluid should come out close nipple release break then squeeze fluid back into caliper as i said this may take a few goes but you will notice the air come out of the nipple which is what it is for and will notice the breaks pressurizing when the air is been removed also the reason for timing is that when releasing the break with the nipple open you will take air up into the caliper which is not what ya want but not a catastrophy either it is easy enough to time and do so dont be daunted by it also as a precaution may be good to get a bottle of brake fluid but not essential good luck and hope it helps
Mar 02, 2011 | 2007 Aprilia RSV 1000 R
Just bought a technomarine watch and can't pull out stem to set time and date
Sometimes the crown is screwed in to help keep it water tight. Turn the stem anti-clockwise to see if it will release "give several turns" if that fails return it for exchange.
Dec 31, 2010 | TechnoMarine CSX01 Wrist Watch
Put new clutch in 2003 cr 250.. start bike and let out clutch in 1st gear and bike doesnt move
firstly remove clutch cable at lever, put into gear and see if its hard to push and turns the engine over - if its easy with little resistance then the clutch isnt releasing fully. check the pressure plate springs on clutch unit making sure the plates are squeezed up tight together and that centre hub is located correctly. if it is hard to push then check cable adjustment. hope this helps
Jul 31, 2010 | 2003 Honda CR 250 R
Can't take off serpentine belt on my 97 dodge stratus
you need a serpentine belt tool for the tensioner bolt. they are a flat bar with hex cut outs in them.you have to release the tensioner first or the belt will not come out.Auto parts places carry the tool.
Apr 13, 2010 | 1997 Dodge Stratus
Got in mountaineer to start would not start tried to jump battery no luck bought new battery because water empty in battery still will not start could it be security problem and what to do
check for bare wire on battery cable then check battery cable to starter and run wire if ok try hitting starter several good whacks if it starts then starter is bad put on new starter but replace solenoid first make sure connector is tight take a pliers and squeeze it a little so it is tight then try to start.
Oct 23, 2009 | 2004 Mercury Mountaineer
Dont know how to get my pliers to lock need instructions
open your vice grips up and put them around the item you are working on then close the vice grips if they are loose around item screw the knob IN til it gets tight around item then open vice grips and give the knob one full turn and put back on item and squeeze the handles together it should lock if you cant squeeze the handles together then back the knob back out until you can get the handles to lock or screw in if still too loose.
Apr 02, 2009 | Irwin Industrial Tool Co No.10R - 3 10"...
Samsung Healthy Living Deluxe Wrist Blood Pressure Monitor Logo
168 people viewed this question
Top Samsung Health & Beauty Experts
Marvin
Marvin
Joe Ball
Joe Ball
Tom Chichester
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
