Question about HTC EVO 4G Smartphone
The charging port broke of from my htc evo 4g phone.
The part where you connect the charger to my phone broke off.
    Scholar:
    New Friend:
  • 58 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Sep 10, 2012
SOURCE:
  • 527 Answers
SOURCE: Can HTC EVO 4G smart phone be used in India on
you can unlock your phone and use it to another network ,but you want cdma services available in specified model , you can use it for gsm after unlocking , if you want to unlock ,you can try codes here http://www.onlinegsmunlock.com/htc-smart/rs7wp9/
Posted on Nov 15, 2010
270rexton
  • 782 Answers
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Posted on Sep 25, 2009
Testimonial: "holy crsp it worked thanx:)"
jerseymark
  • 358 Answers
SOURCE: how to connect jawbone bluetooth device to htc evo
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Posted on Oct 02, 2010
  • 17 Answers
SOURCE: My htc evo 4g keeps freezing on me
download 3 apps. cache cleaner cleans temp mem, task killer shuts down unused open apps, memory booster keeps ur phone from stuttering, and apps to sd moves apps to your sd card to free memory.
Posted on Jan 08, 2011
vanherringto
  • 1738 Answers
SOURCE: I just purchased a new HTC Inspire 4G cell phone
Thanks for visiting FixYa!
Just a note:
HTC Sync cannot be used for file transfers of music and videos.
To do that, you need to remove your phone's memory card - insert it in a PC - download the Music/Videos to the PC - then transfer them to the memory card.
Posted on Mar 25, 2011
My HTC evo Design 4g wont charge with new batteries and new HTC chargers. The devices indicators say its charging both the orange LED and the green battery icon on the screen show it charging but it dont...
You're battery and phone may be HTC but your battery may only be 3.2 V while your phone is 5v try looking at the battery output and the phone output they are both in the battery compartment. I had the same problem with my HTC EVO V
Oct 20, 2014 | Cell Phones
Charge htc evo 4g lte with broken charging port or how to fix charging port
unless you can open the phone and have soldering skills, take it to a local repair shop to replace
Mar 07, 2014 | Cell Phones
The ringer shuts off by itself
Dump the phone. I have had the HTC EVO 4G and it was a nightmare. Screen broke without a drop,screen kept freezing and everything else that could go wrong did go wrong. I had had enough and chucked it on the freeway one day and went with an iphone. EVO is a first attempt by HTC to come up with a competitor to the iphone. Good luck
Nov 27, 2012 | HTC Evo Design 4G
My htc evo will not charge and the charger does not have a shortage.how do i fix it?
probably damaged the connector where the charger plugs in
If it has a usb port, can you charge it from a computer ?
Jun 28, 2012 | HTC EVO 4G Smartphone
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My evo 4g will charge from the usb connected to my computer but the computer says the phone isn't connected. i downloaded the latest version of htc sync and it still says not connected
The problem sounds to be with the USB port is partially damaged and not making connection fully with the board. There are about 4-8 connections on the USB connection and I believe only 2 need to be connected to charge the phone, but all need to be connected to communicate with the computer. I suggest you first try a different USB cable and then look for a local repair center.
I use Photo Tech CPR in NYC for all my repair needs. www.cpr-nyc.com
Good Luck
Paul
Jul 16, 2011 | HTC EVO 4G Smartphone
Dropped MY EVO HTC broke glass need to find where to get a replacement and how to properly remove glass and replace.
HTC might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at HTC Evo Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Aug 07, 2010 | HTC EVO 4G Smartphone
HTC EVO 4G Smartphone Logo
236 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
