Question about Kenmore 24 in. 17053 Stainless Steel Built-in Dishwasher
Kenmore Dishwasher 17053 clean light blinks and will not start
Ordered a new controller, did not fix it
Stock # 17053 type 577D
Model# 665.17053401
Serial# FS2201344
  • 2 more comments
  • vnaff Dec 25, 2008
    No it was part 8564546 from Sears Parts direct, the original control board was also whirlpool 8564546
  • vnaff Dec 26, 2008
    Thank you very much, I'll give it a try.
  • himo Mar 31, 2009
    I have the same problem .we have been hearing a high whining growling sound for a while now the clean light blinks and will not start
  • Robert Artiaco May 11, 2010
    was it part 8194200? where did you get the control board?
    Sergeant:
    Champion:
  • 338 Answers
There is an "upgrade kit. it contains a control board and a new element. the element is redesigned to overlap the thermistat and has a higher wattage. you should return that board and get the kit and if you call and schedule service they should repair it for free under a service flash.
Posted on Dec 26, 2008
  • Robert Artiaco Dec 26, 2008
    no preoblem. let me know if you need help with anything else
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
The clean light on kenmore dishwasher elite keeps blinking and will not stop
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually there is a tech-data sheet located on the other side of the toe-kick panel which will explain the meaning of the varius blink codes, but you might still need to call a technician to fix the problem. Don't forget to put that tech data sheet back so he can find it and use it to fix your dishwasher!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 16, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher clean light blinks
This is due to a problem with heating of the water. I have put together some instructions on what to do and how to reset the control so you can use the dishwasher. Follow the link below and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 07, 2010 | Kenmore Dishwashers
Was running a wash cycle lastnight and it stopped running and the clean (green) light is blinking and won't turn off. When I push the Start button, there is a red blinking light. Help. It is a Kenmore...
Is your washer a front load? Does it have a small window where you read the stages or minutes left?
If so is there a code flashing in thet window?
Also what year is your model?
Oct 21, 2009 | Kenmore Dishwashers
Dishwasher clean light blinks after i turn it on
If the Unit is one year old or less it will be repaired free of charge if you contact the manufacturer, they will find the nearest certified appliance repair company in your area.
The problem will turn out to be a bad control panel or control board.
Good luck
Sep 12, 2009 | Kenmore Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 24 in. 17053 Stainless Steel Built-in Dishwasher Logo
238 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
