Question about Siemens 2 single pole 15 amp breaker
I have 2 siemens circuit breakers that won't reset. How can I do
Two 15 Amp circuit breakers won't reset after they were overloaded. How can I reset those?
    Genius:
  • 1,605 Answers
Unplug the appliance that is overloading the breaker.
reset the breaker, plug in the appliance. if the breakers pops, then the appliance is the problem.
you may want to check the appliace manual and make sure the breaker is rated for the appliance you are using.
Posted on Dec 30, 2008
What are the circuit breaker part numbers for a Siemens Ite G3030MB1200 Panel
Go to any home store and ask them, they will have the breaker or one to use as a replacement
Sep 04, 2014 | Siemens Electrical Supplies
I had a house inspection and in the main panel I have a 20 amp QT breaker that is rated from 15-35. I have a 20 gauge wire and and a 15 gauge wire running to this breaker. Inspector says I need a 15
He is correct. I'll not go into the particulars but the fact is, you have two separate circuits connected to the same breaker. Separate the two circuits by installing another 15-Amp breaker. Although I understand your situation, please understand wire gauge and electrical amperage are two different animals. Breakers are rated in Amperage and electrical conductors are sized by wire gauge. That said, the 20 gauge wire you speak of is actually a 12 gauge conductor and the 15 gauge wire as you say is a 14 gauge conductor. Have a good day.
Aug 30, 2014 | Siemens Ite Twin Q1515 Circuit Breaker...
Reset instructions for a wls2f320 main breaker
Turn off all other breakers. And try reset again.
3-phase solid state breaker from Siemens
Contact siemens:
http://www.siemens.com/entry/cc/en/
Unfortunately the Siemens site does not show results for WLSF320, but has results for solid state circuit breaker:
http://www.siemens.com/corp/apps/search/en/index.php?q=solid+state+circuit+breaker&lang=&site=siemens_c_ww&lr=lang_en&as_filetype=&client=siemens_f_ww
Otherwise I cannot find .pdf file to help more.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 09, 2013 | Electrical Supplies
Will a Siemens ITE Q1515 15 amp tandem breaker fit into a 200amp Siemens Series E panel G4040ml1200?
yes it will, you need to always make sure that you put the same brand in the panel box, good luck
Sep 18, 2011 | Siemens Ite Twin Q1515 Circuit Breaker...
Lights get bright then dim over and over can hear buzz noise from box where the main is
Sounds like a loose connection or overloaded breaker, Please call a Electrician due to high voltage in box
Dec 20, 2010 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Keep tripping breakers can i just remove the 15 amp breaker and replace it with a 20 amp ??
I would not go to larger breaker size until I knew why 15 amp breaker is trippingIf you find out that 15 amp breaker is tripping because it is being overloaded or that breaker is getting weak. Then I would replace breaker with the same size because they may have wired some with 14-2 wire instead 12-2, I would not feel comfortable pulling 20 amps, on 14-2 wire. That is my suggestion for what it's worth. Thank you.
Nov 20, 2010 | Sea and Sea Blue Sea 7327 Circuit Breaker...
Breaker wont push back in
it is still detecting an overload in the circuit. Take the black wire off the breaker and see if it will reset. If so then you will have to trace the wires down to find the short circuit. If it doesn't reset then the breaker is bad
Jan 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
I need to strap two single pole breakers together to make 2 pole.
this is a double pole circuit breaker that is used for a 240 volt device the bar in the middle is to shut down at the same time you can take it to a hardware store to replace it but the bar is factory made siemens is one common breaker or there might be a substute they can give you also
Dec 01, 2008 | Siemens 2 single pole 15 amp breaker
Siemens 2 single pole 15 amp breaker Logo
718 people viewed this question
Top Siemens Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Steve
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
