Question about Yamaha RX-V661 Receiver
WII How do I hook up the WII to the RX-V661? I input it into the front panel and pressed the aux button on the remote and nothing happened
  • Julie G Workman
    Julie G Workman Mar 23, 2009
    I have the same problem. Purchased the Wii 12/08 & have never been able to get video & sound @ the same time. Purchased additional component cables to go with the Wii, but still no action. The Yamaha RX-V661 is connected to the TV w/HDMI cables. There is a Digital Cable Box as well as an Oppo DV-981HD DVD player in the works. I have plugged into every plug on the receiver, have tried the Cable Box plugs, and cannot distinguish where the video portion of the cables go into the Cable Box, but have tried those as well. Any advice will be appreciated.
Had the same problem- but had success when I connected the wii to my DVD player, which then HDMIs through the reciever and then HDMI to my projector.
Posted on Jan 18, 2009
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
Wrong remote
no but you can change the settings from the front panel of the unit.
Feb 12, 2014 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 powers on when I hit the power switch. After two seconds it goes to stand by.
try holding the 'straight' and 'audio select' buttons and press power. What does it say on the front panel? Should say some kind of protect: I, DC, PS. This will help narrow down where your problem is.
Oct 15, 2013 | Yamaha RX-V661 Receiver
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Wii systme not working
Just press the input button on your remote controller until the screen comes up. Make sure you are plugging the RCA (Red/Yellow/White) cable into the standard input cables on your TV.
Dec 20, 2009 | Nintendo Wii Console
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
No DVD Picture
you need to assighn the input for the component video page 78 of your manual will explain how
Dec 28, 2007 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
185 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
