Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Battery cover won't open
Took out battery to charge, put back in, tried to open back up and it won't budge. Help
Try tapping it or even shake your camera to try and losen battery if not try to force open not enought to break but a firm grip this has happen to me befoe
Posted on Dec 30, 2008
I have a 2006 new beetle, just put in a new battery about a week ago. It drove fine. My problem is, the car won't start when i turned the key. I tried many attempts, but just won't budge. Is
Hi there, with this kind of problem in general, you have to look on any source from where your battery is being drained. Check your new battery if it is drained again. If the voltage is below 12V means there is a close circuit that is using your battery while it is stopped. Recharge your battery and try starting your car or ask a friend to jump your car. If it wont start check your starter motor. Another factor to think of is maybe your alternator is not charging your battery.
Mar 26, 2013 | 2006 Volkswagen New Beetle
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
How do you take apart a gateway zx4800-06 all in one computer to put a new hard drive in. I took the case screws off but the cover won't budge and I don't want to take a chance of damaging...
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Aug 12, 2011 | Gateway ZX493131e Notebook
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Cannot open battery case
Put your thumb on the cover, push it toward the back of the camera and then toward the near end of the camera, and then it will swing open. The directions are indicated on the bent arrow on the cover.
See the illustrations in the "Insert the Batteries" section of the manual (page 12 in my copy).
Jan 16, 2009 | Nikon COOLPIX L18 Digital Camera
Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
Battery cover
the manual shows you how to take the battery cover off the phone
Jul 09, 2008 | Samsung SGH-E900 Cellular Phone
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
