Drills / Drivers
Problem for Drills / Drivers
Generic problem for all Drills / Drivers
Milwaukee Tools Li-Ion battery stuck in the...
By robberry on Dec 25, 2008
Milwaukee Li-Ion battery is stuck in the charger. It appears that I jammed the battery in the charger 180 degrees reversed so that the large tab on the battery is aligned where the small one should be. I just got the thing for Christmas and was too excited to notice the keying features. I'm surprised that I was even able to do this since I didn't really try that hard to put the battery in. Anyways, the battery is not fully seated in the charger and the large tab is barely visible when I look into the charger port. How do I get the battery out without damaging the battery and the charger?Thank you.Rob
Solution #1
posted on Dec 26, 2008
Not Rated)
rowdy45176
Rank: Guru  Tools - Building & Power  Expert
Rating: 91%, 581 votes
Hopefully you didn't drive it into the charger. What I would try is have someone hold the charger and you grab the battery and try wiggling it back and forth to free it up. If not you might try holding the battery and TAPPING on the charger with a piece of wood GENTLY to remove it.Hope this helps.
Dave
Was this helpful?
Yes
No
Popular Solutions for Drills / Drivers
Questions and Unsolved Problems for Drills / Drivers
Answer
what is the best impact driver
Answer
where to find replacement power switch for craftsman 18 volt drill
Answer
how to change brushers in makita hr 2020 110volt sds drill
Answer
how do i change a chuck on a makita mtx cordless drill
Answer
makita BDF451 chuck is stuck with bit in it
Describe your Drills / Drivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Drills / Driver Experts
Top Garden & Power Tool Repairmen
in , PA
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
