Question about Yamaha RX-V661 Receiver
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
  • dgibbon Dec 30, 2008
    i also just got the wii plugged it into the video aux and nothing.
    ideas ?
  • Anonymous Apr 26, 2009
    Same here. I just purchased a Wii and tried the Auxillary input and got nothing. I have a singel HDMI cable from the receiver to the LCD. If I select the "Aux" as the input, why should I need a another cable from the Will directly to the LCD?
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Posted on Jan 04, 2009
How would i be able tp put aux/video on my TV without a remote? All we have are the buttons that are lready on the tv, we can go to menu but we dont know where to go after that. Please help, we are trying...
Some Tv's will allow you to simply channel change down for example.. 3,2,1, then the input/or aux channels show up as comp, HDMI,AUX. If you have tried this and it doesnt work and there is no button on the tv that says source/input or aux you may be able to change it in menu. Look for an option in the menu that says source. Unfortanatly not many tvs have this option.
Dec 13, 2010 | Televison & Video
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
I dont know how to connect the wii to my rx-465 receiver.
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
Mar 11, 2010 | Yamaha RX-V463 Receiver
Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Jun 16, 2009 | Yamaha RX-V463 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
WII
Had the same problem- but had success when I connected the wii to my DVD player, which then HDMIs through the reciever and then HDMI to my projector.
Dec 25, 2008 | Yamaha RX-V661 Receiver
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Nov 21, 2007 | Orion1934 19" TV
Yamaha RX-V661 Receiver Logo
391 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
