Question about Mintek Portable DVD/CD Player w
Minrek, Portable DVD Player, Model: MDP1825
Problem: Stopped Playing DVD's, but- music CD's play fine. Message: "NO DISC". I feel that all is needed is to align the DVD reader, since CD's play just fine! Observations: 1). DVD disk does spin. Says "loading" makes noise. 2). Comes back after about 2 min. with "NO DISC". 3). Tried other DVD disks, same problem. Things tried. 1). Cleaned the "Eye" with a q-tip with Isopropyl Alchol (DVD's still didn't play, but- music CD's do play). 2). Cleaned the "Eye" with a q-tip with Acetone (DVD's still didn't play, but- music CD's do play). Cause: Not sure. The 13 year old girl is very careful with this item because it was a special gift. It cost over $200 USD at the time! Everyone wants to charge $100 min. for parts, to look at it is free, but- won't say how much to fix it. Notes: You can buy lots of broken MDP1825 DVD Players on e-Bay for $0.99 so I just hope it's not junk! I want to fix it for her but the cost to have someone repair it is to much based on todays prices for players. I have looked for a sevice guide for the MDP1825 to see how to align / adjust the DVD side of the player. (No Luck finding one). I'm not bad with tools since I work on PC's all the time, but fixing a DVD player is something I have not done! Can you offer me a solution to this problem. Thx
  • Bill Banik Jun 05, 2007
    We'll since everyone said it needs more power I did try plugging it directly into the wall, note: did nothing more!~
    So, I'm giving up on the repair and just getting a new one for my son's friend. It's the best thing I can do.
    Thanks for all your help.
    Bikster-
  • 4 Answers
Okay, i tried this, and it didn't work. I had to find some isopropyl, which took me a while, and i have a feeling that this thing is unreparable. Anyway, i don't know how to adjust the laser, so juan's idea is probably out. Anyway, these things are always cheap on ebay, and even one that isn't 99 cents will work. I have no idea how much this thing cost, so i can't set a goal. Thanks anyway for the ides, and keep trying.
Posted on Jan 28, 2008
  • 76 Answers
Have to agree with juan,more than likely optic faulty.will play cds as less power needed from optic to focus on tracks laid down on cd.more power needed on dvd as tracks are laid closer together and optic has to work harder to read information.
Posted on May 11, 2007
    Scholar:
  • 125 Answers
Qtip , alcohol and acetone ? I am almost sure that you have already ruined the lens. In many of the CD or DVD players that I have repaired, the problem is the degradation of the power of thelaser. Im computer drives there are cases that I was able to fix the porblem by adjusting the power of the laser. this is quite dificult as the trimmer potentionmeter is very small and most often very hard to access. Usually this trimmer is located in the laser assembly.. Another dificulty is that the adhustment should be procise, too much power will also not work. My success rate of this procedure is only about 50-70 % But because you already cleaned it with Qtip, maybe the lens are no longer aligned and because of the alcohol and acetone, the lens may not be clear anymore.
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Nov 15, 2010 | TruTech LMD-5702RT Portable DVD Player
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
Problem with voice sound on DVD player FX900 Sony. Can hear audio (music) fine but voices are muted.
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
Aug 17, 2009 | Sony DVP-FX810 Portable DVD Player
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Says no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
Disney Princess CD Player will not play music
try cleaning the laser with a q-tip if the laser is dirty from finger prints or dust it won't be able to read the disc therefore won't play. Clean laser and if that doesn't work then the child may have damaged the player in a fashion that would be better to get him/her a new one.
Jan 08, 2009 | Disney Princess Portable CD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Screen displays "Error data" when trying to play a DVD
My understanding is that the DVD player uses a different lens to the CD player. So the DVD lens might need cleaning. A CD lens cleaner would not correct the DVD side.
Oct 04, 2017 | GoVideo DP8240 Portable DVD Player with...
Mintek Portable DVD/CD Player w Logo
163 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
