Question about iLO MP3 Player
Help MY WMA/MP3 PLAYER WONT TURN ON HOW DO I GET IT TO
Maybe you have to charge it longer if you did send it back
Posted on Dec 25, 2008
It wont play the downloading songs
The following may help:
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Element Electronics Zr-Element Digital...
Music downloaded as WMA from PC to MP3tech MP3S4 wont play
Your player should support both MP3 and WMA files. What happens when you try to play an MP3 instead? Have you tried other bit-rates? Those you are trying may be too high or low.
Jun 29, 2009 | Audio Players & Recorders
Mp3 player not turning on
I had the same thing happen and I just figured it out!!! Why this thing didn't come with these instructions is beyond me. That's why it was on clearance at the Walgreens!
Ok, after you have your music sync'd and it has been fully charged look on the left side of the MP3 player and you will see a button that says: ON HOLD OFF
Keep the button under OFF and just hold down on the play button and the unit will come on. The button on the left is just for holding your songs it is not to turn the MP3 player on or off. The PLAY button is the power button.
Hope this helps!
May 30, 2009 | GPX MW-3847 MP3 Player
there is a hold butin on the left side
Jan 19, 2009 | GPX MW-3847 MP3 Player
My Sansa Shaker wont take the music.
check the file types from you music the shaker only plays MP3 and PCM WAV  file types. You may have WMA (if u used windows media player) which will not play on the shaker  (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format  from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Dec 28, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Wont play wma files
Different players will accomodate different formats. You might have to reformat the WMA files on your PC and then transfer to your unit.
Nov 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Sync
Make sure they are in the right format mp3 vs. wma vs. aac
Mp3 is best
WMA works under certain conditions
AAC doesn't work at all
Jul 15, 2008 | Philips GOGEAR SA6045 MP3 Player
MyMusix PD-6110 MP3 Player wont play any songs
Unfortunately, your files must have gotten corrupt. This issue is most prevalent if you disconnect the mp3 before it has completed the transfer of songs.
To fix it, format the mp3 by plugging it into the USB port, right clicking the drive that is displayed and choosing "Format". This will remove all songs from the mp3 player. Afterward, you can re-add any songs that were lost. But make sure when disconnecting, you see no loading animation on the screen. Then right click the "Remove Hardware" icon on the bottom right of you screen, choose "Stop". Check again for a loading animation on the screen (if there is one, wait until it stops), and you can remove the mp3 from your USB port.
Jan 23, 2008 | MyMusix PD-6070 MP3 Player
Unknown Format
It sounds like these wma files have DRM protection.
You can still play these songs on your mp3 player, but you must use Windows Media Player to transfer them.
To do this, connect your mp3 player to your computer, then open Windows Media Player. In WMP select "Sync" & you should see your mp3 player in the right-hand pane. Drag & drop your wma files across. It's a slow way to do it, but the only way to transfer wma files with DRM.
Let me know how you get on!
Jan 05, 2008 | Nextar MA566 MP3 Player
Mp3 player wont download songs
I would recommend going into 'my computer ' and going into the music folder in your Rio. If your music is in here then make sure that it is a supported format (Eg. MP3, WMA. AAC is not supported)
If it is in here and it is a supported format then try formatting it and putting the tracks on again.
If that doesn't work then try upgrading to the latest firmware.
Hope this helps,
Mowcius
Dec 25, 2007 | Rio SE510 (512 MB) MP3 Player
18 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
