Question about Universal MX-900 Remote Control
Mx-900 universal remote - batteries good - seems to be dead
No display. Not sure if there is power. Tried fresh batteries.
  • kehewz Jan 19, 2009
    I have the same issue. Display completely blank, tried two sets of new batteries. It's dead!
5 Suggested Answers
  • 23 Answers
SOURCE: MX-900 Universal Remote Control
you might want to reprogram it with different codes. it's a classic problem.
Posted on Oct 15, 2008
  • 95 Answers
SOURCE: I can not get my MX-900 Universal Remote to connect to my compute
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Posted on Aug 12, 2009
toolkits
  • 1099 Answers
SOURCE: Controller will only turn equipment on and off.
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
Posted on May 20, 2010
SOURCE: we have an MX 900 universal remote and got a new
You will have to go to universalremote.com and use the Contact Us (top right of webpage). Fill out the form and tell them that you need the editor software. They will have you fax them a form with your remote serial number and some other information and then they will provide you will a link to download the editor software.
Posted on Dec 17, 2010
Vivitar vivicam 6300 will not power on with fresh batteries
I think it is the problem not oriented with battery. Just make sure that your cam battery placing area have any rust. If so just try to clean the rust and re-insert the battery and check it off.
Jul 29, 2013 | Cameras
Ws 2800 rain not displayed
I tried this and it worked fine
FACTORY RESTART:
A Factory Reset will erase the connection between the Display and the Thermo-hygro sensor and allow a fresh connection to be re-established. It is recommended to have the display and all sensors 5-10 feet apart for this restart.
ENTER PROGRAM MENU
Press and hold the SET button until you enter the program menu. Press and release the SET button until you see 'rES oFF' flashing.
FACTORY RESET ON
Use the UP ARROW key or DOWN ARROW key to turn rES on.
CONFIRM & COUNTDOWN
Press the SET key to confirm and a countdown timer will begin counting down from 127. When the timer displays dOnE, you must remove the batteries from the display for 10 minutes
REMOVE BATTERIES FROM THERMOHYGRO AND RAIN
While the batteries are out of the display, also remove the batteries from the Thermo-hygro sensor and the Rain sensor. Wait 15 minutes.
GENTLY KEY THE WIND SENSOR
Gently key the wind sensor one time to activate the sensor.
INSTALL BATTERIES INTO THERMOHYGO AND RAIN
Insert fresh alkaline batteries into the Thermohygro sensor and Rain sensor make sure to check polarity with the markings on the battery cover and inside the battery compartment. Wait 2 minutes.
INSTALL BATTERIES INTO DISPLAY: Insert fresh alkaline batteries into the Display. Make sure to check polarity with the markings inside the battery compartment
15 MINUTES: Wait 15 minutes for the outdoor weather data to display. If the outdoor data displays dashes after waiting for 15 minutes, repeat the steps of restart.
AZ Road Runner
Sep 15, 2012 | Lacrosse La Crosse WS-2800 Series Wind Cup...
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Equity Wireless thermometer Outside temp never registers
From their instructions:
RESTART:
  • RESTART DISTANCE: For best results please bring the outdoor sensor in the house and place 5 feet from the display unit.
  • REMOVE POWER: Remove batteries from the sensor. Next remove batteries (and/or a/c cord) from the display.
  • DISCHARGE ELECTRICITY: With the power source removed, press one of the buttons on the display at least 20 times to clear all stored power. Please do this even if the display is blank to remove any remaining power. Verify the display is blank.
  • UNPOWERED FOR 15 MINUTES: It is important with most of our displays to remain without power for at least 15 minutes.
  • NOTE: Failure to allow a display to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing segment on the display. The instruction manual describes a setup for a new unit that has not had time to build up stored power.
  • BATTERIES: Please be sure you are using fresh batteries tested to a minimum of 1.48, on a voltmeter that reads in numbers.
  • SENSOR FIRST: Place batteries into the outdoor sensor first. Make sure they are installed according to the polarity diagrams in the battery compartment.
  • DISPLAY NEXT: Install batteries (or a/c cord) into the display according to the diagram in the battery compartment.
  • CONNECTION: Allow the sensor and display to remain 5 feet apart for 15 minutes to establish a strong connection. Do not press buttons at this time. You should see a reading on the outdoor temperature area in the first minute.
Gary
Jan 07, 2011 | Garden
It wont power up at all. I have tried batteries,
1 - Check the battery contact and make sure the batteries in the flash are good.
2 - check the plug for the turbo, make sure it is not damaged, as well as, the high voltage plug on the 580 flash. If those contacts look dirty or mushroom shaped, you will nee the flash repaired.
3 - obviously make sure the turbo is charged
Sep 30, 2009 | Canon SPEEDLITE 580EX TTL Flash
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Battery/power-up problem
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Oct 27, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
Universal MX-900 Remote Control Logo
152 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
