Question about Microsoft Windows Vista Ultimate Edition
WindowsMail "the connection to the server has Failed"
I am unable to "Share" photos using that function of HP Photosmart Essential. Windows Mail, which is the default on my computer running Windows Vista Ultimate, fails to connect and provides this error message 0x800CCC0E
  • stephaniecus Apr 03, 2009
    no matter what i do i cant send any photos
Go to microsoft technet and type the error code into the search bar
Posted on Dec 27, 2008
Unable to send e-mails using windows mail
The connection to the server has failed. Account '<account name>', Server: '<SMTP server name>', Protocol: SMTP, Port: 25, Secure (SSL): No, Socket Error: 10051, Error Number: 0x800CCC0E
To resolve this behavior, change the SMTP server for your e-mail account to use the MSN SMTP server. To do this:
1.In Outlook Express, click Accounts on the Tools menu.
2.Click the Mail tab, select the account that you want to change, and then click the Properties button.
3.Click the Servers tab.
4.Under Server Information, delete the entry that is in the Outgoing mail (SMTP) box, and then type smtp.email.msn.com.
5.Under Outgoing Mail Server, click to select the My server requires authentication check box, and then click the Settings button.
6.Under Logon Information, click Log on using.
7.In the Account name box, type you MSN Member ID (everything before the at sign (@) of you MSN e-mail address).
8.In the Password box, type your MSN account password
9.Click to select the Log on using Secure PasswordAuthentication check box.
10.Click OK to close the Outgoing Mail Server dialog box.
11.Click OK to close the <Mail Account> Properties dialog box.
12.Click Close.
Mar 05, 2014 | Medion Computers & Internet
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
Jul 22, 2010 | HP Photosmart Premium C309A All-In-One...
Unable to install hp Image Zone & iris on Windows Vista. Help...
HP Image Zone is no longer designed by HP for Vista PC's
There is another software available Called HP Photosmart Essential. Download the Software from this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414784&lc=en&dlc=en&cc=us&product=3857372
HP Photosmart Essential is also called as HP Photo Creations
Jun 22, 2010 | HP Scanjet 3770 Flatbed Scanner
Using my F380 all in one, how do I scan to my
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Place your original print side down on the left front corner of the glass.
2. Press Scan.
3. Make any edits to the preview image, and then click Accept when you are finished.
To stop scanning ➔ Press Cancel on the control panel.
If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
or this if you have Vista:
If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
If this is the case then you can download a free program called IrfanView from there site: http://www.irfanview.com/
Click the Start icon. Click All Programs .
Click Windows Photo Gallery .
Click File and then click Import From Scanner or Camera .
Click Import .
Click Scan .
I hope that helps..
Regards
Mike
May 26, 2010 | HP DeskJet F380 All-In-One Printer
Have a HP4180 deskjet printer that also scans. How to get images in the computrer?
The user manual that came with the printer should explain how to do this.
See extract below
Scan an image
2. Press Start Scan.
3. Press OK to select the default application to receive the scan, or press to
4. Make any edits to the preview image, and then click Accept when you are
finished.
Dec 19, 2009 | HP Office Equipment & Supplies
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Cant take pictures on webcam
  1. Double-click the HP Photosmart Essential icon on the Windows desktop.
  2. Select View>Get images>From Scanner. The Select Device dialog box appears.
  3. Select HP Camera and then click OK.
  4. A warning appears to indicate that the device isn’t a scanner. Click Yes.
  5. Click Capture to take a picture (snapshot).
  6. Click Transfer to save the picture in the My Documents/My Scans/<Current Month> folder.
Now you are ready to edit and share your photos with HP Photosmart Essential.
Apr 14, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
Microsoft Windows Vista Ultimate Edition Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
