Question about Coby CBY705 MP3 Player
Mp705-4g will not turn on when not connected to the charger. while on the charge it works fine but unplug it and all you get is a frozen picture of the last thing you saw before you unpluged and then black screen. I have tried resetting it .... called customer support but nothing. Please help!!!
  • Anonymous Dec 26, 2008
    The player will not turn on unless connected to the computer. The clear top seems to be loose at the top near the power switch. The player is less than 6 months old.
  • nickhester Jan 02, 2009
    my
    Coby CBY705 MP3 Playerok this iis really making me mad i have tried everything i possibly could i first opned my mp4 player on christmas so that means its still kinda new one day i was listining to it and and i turned it off so later i triedto turn it on and it wouldnt turn on :[so i tried ti charge it didnt work so i thought it was the usb cable so i bought another and still not working so i was maby its the computer but that wasnt the problem because my blue tooth charged just finr off of the computer so what is the problem???
SOURCE: coby mp-c7095 mp3 player will not charge was working but not now
I bought a Coby mp-c7095 and could not get it to turnon. I charged the battery for more then 24 hours and it still would not turnon.
The problem was easily fixed. The red battery wire was pinched during assembly and shorted to the back cover. I put a small piece of tape over the bare wire and carefully reassembled the unit. Now it works great!
Posted on Mar 19, 2008
  • 53 Answers
SOURCE: My Coby Mp705 4G Wont turn on Ive tried everything
You probably overcharged it and now you have shorted out the battery . I suggest that you try to get a new battery or buy a whole new one.
Posted on Aug 13, 2009
webmaster21
  • 803 Answers
SOURCE: My Mp836 player/Coby sceen is frozen.
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds. IF THIS DOES NOT WORK TRY THIS: Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Coby's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 05, 2009
YourZEN
  • 820 Answers
SOURCE: when plugging in our coby mp822-4g mp3 player the
When using the MP822 for the first time it should be charged for 8 hours before using.
When the player is coming up with the welcome screen while connecting to a computer, switch the player off while connected.
Connect directly to a running computer, charging the device (in the power off status) for a longer period. The USB symbol should be displayed on the player's screen.
When not being able to get the player in the off status, reset the device:
1. Disconnect your player if it is connected to a computer.
2. Use a paper clip to gently press the Reset button located on the bottom of the player.
When this was helpful I'd appreciate your vote.
When needing more information, just add a comment.
Posted on Jan 01, 2010
SOURCE: User Manual for Coby MP705-4G MP3 player
In can't delete songs off my coby mp705. If anybody can help that would be great. Thanks.
Posted on Mar 13, 2010
Bluetooth Crashed, won't turn on or off (can it be reset?)
Is there any way you can phisically disconnect the battery, wait about 3 minutes, and reconnect it? This would force a reboot, or re-initialize the headset's programing.
If it does work, be sure to let the battery drain down to cut-off before placing it in the charger. That way, the charger will be "on the same page" as the battery's charge level. It's worth a shot if you can do that.
Mar 20, 2017 | LG HBM-235 Headset
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
E260 Wont Turn On
on the desktop click right button and click properties.now go to the apperance below the windows and buttons chane it as windowsxp style.
Jun 14, 2008 | SanDisk Sansa e260 MP3 Player
Coby CBY705  MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Peter Dragonetti
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
