Question about Microsoft Windows XP Professional
Recovering My Dcuments from failed system
The fan in my laptop (ThinkPad T42) died and won't boot. I pulled the HDD and put into external IDE-to-USB enclosure and can plug into antoher computer.... but when I try to access the files in My Documents for one of the user accounts from the laptop (which was a password-protected account) I get the error "Access is denied."
How can I get access to these files? The computer I'm now using is also WinXP Pro and my username & password are the same as the laptop that died.
  • contest768 Dec 25, 2008
    [Tech Mobile] Does your solution require booting the OS from the external drive?
  • 48 Answers
You will need to boot to safe mode & then right click on the folder you cant access, choose the option of security, (or properties then security) under the user list click add & type in everyone. Once you click ok tick full access then to advanced & find the option of ownership there should be an option where you highlight the username you are currently logged in to then a tick box for take ownership click apply & it will go through changing the folders & files within that folder to show up under in your current system.just browse to it as you normally would & you can access and copy as normal.
Posted on Dec 25, 2008
  • Murdo Maciver Dec 25, 2008
    No you boot from the pc you have the enclosure attached to.
You have to take ownership of those folders. Right click on the folder and open the Security tab
Operating system not found
Ensure your BIOS settings are allowing the HDD to be a boot device, preferably in first position in this case. (possibly F12 available for quick boot device setting) otherwise F1 on power up.
Try booting with CDROM pulled. Also remove HDD, inspect & brush pins with an old toothbrush and some IPA or WD40.
Failing that, get a copy of Linux Puppy ver 4 onwards on CD (free download & burn at a UK library) and boot your laptop (set at F12 for CDROM). If you can browse your HDD it may have a boot sector problem - you will need a copy of PART244.exe or FDISK on a CDROM to check further.
Nov 06, 2012 | IBM Lenovo ThinkPad A30 ThinkPad A31...
My ibm thinkpad will not start up, even in safe mode. unmountable boot volume keeps coming up
Hi there.
Remove all usb flash drives or external hard drives connected to the laptop.
If no flash drives or external hard drives are present the you will need to reboot your system and press the delete key repeatedly until you get into the BIOS. Once in the BIOS you will need to locate boot disk priority. Set priority 1 to the laptop's main drive and priority 2 to the CD/DVD drive.
Now it should first try boot on your hard drive with your operating system on it. If after this you still get the unmountable boot volume error then your hard drive may be corrupt.
~ Slasher_X
Sep 25, 2011 | IBM ThinkPad T42 Laptop
My ibm t42 has a bad video card, should I change the motherboard cause graphic card is attached to ?
The T42 Thinkpad is an old model, if it was me I would not get a new motherboard (if you can get one).
I would get a later model and better laptop for may be a little moer cost.
You can put the hard drive from the T42 into an USB hard drive adapter case and use it as an external USB hard drive.
Aug 12, 2011 | Computers & Internet
I have a t42 it wont boot up it says operating system not found can this be fixed?
Definitely!! Please ensure that you have not connected a USB drive or external hard drive before booting up the laptop.
Also, it seems that you will have to run the recovery CD on the laptop to get the OS back up and running.
Regards
Anand Gupta
Mar 25, 2011 | IBM ThinkPad T42 Notebook
How can i unlock my thinkpad t42
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Unfortunalty, no other ways other round. Thanks and have a nice day J-
May 17, 2010 | IBM ThinkPad T42 Notebook
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
Got a ibm thinkpad t42 the os is windows xp. it will not boot I get the message bootmgr is compressed restart what do i do?
fist you have start ypu laptop in safe mode you laptop is reboot time press F8 key and select the safemode and after use normal mode and your problem is still pressnet pls reinstall windows xp.................100% ..........
Mar 27, 2009 | IBM ThinkPad T42 Notebook PC - Intel...
Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
Mar 21, 2009 | IBM ThinkPad T30 2366 Notebook
Microsoft Windows XP Professional Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
