Question about Maytag Neptune FAV6800AW Top Load Washer
Error Code "od" while trying to start machine
The machine will not start. When the start button is pushed the beeper beeps and error code "od" is displayed on the readout screen. Teh manual reads this is a safety feature and that the lid must be opened before another cycle is started.
  • 4 more comments
  • Mike Blaney Apr 15, 2007
    We have unloaded, tried to start with nothing in washer, loaded a full load and tried that also. Still no luck.
  • Mike Blaney May 06, 2007
    Solution to the problem is that the left lock mechanism was faulty. Replaced it and all was fine.
  • trinistud Dec 14, 2007
    I have a neptune TL washer for the past 4 years and every time I try to start it I get the error code "od". I unloaded the machine and tryed it again with no joy. Can you h elp me with this problem.
    Thanks,
    Dave
  • risris May 18, 2008
    I too have the od code the repairman was here and said I need a left lid lock replaced and he can be back in 2 weeks with it. I have 3 kids 2 weeks is to long. Does anyone know if there is a way to disconnect/bypass this safety feature? Or is I got that part how I could put it in myself?
  • inkgravy Jul 08, 2008
    Same exact problem manual says to open the door. Tried and left unplugged overnight. Thank you for the info will try it. Washer is less than two years old.
  • t_lestrud Jul 21, 2008
    I have the same issue. And frankly I am going crazy. I have husband and three kids and laundry is piling. I thank you for the tip. Were do I buy this part. And how soon can I get it. My husband has removed the left lock and fussed with it and it comes back to life. But, that is temporary fix. Hopefully This will fix the problem.
    New Friend:
In my case turns out "od" meant Open Door - imagine. Anyway, opening and reclosing the door worked. Thank you.
Posted on Apr 03, 2015
I had a maytag repairman do it but I will do it my self from now on. It was really simple to do and it came with installation instructions in the box. Have had no problems since. The Maytag part number is: 25001048
Posted on Aug 22, 2007
    President:
  • 1,294 Answers
Could od mean overload? Reduce or actually weigh load and re-try
Posted on Apr 15, 2007
  • prem mathew Apr 15, 2007
    These machines hv instructions re load, a max and a min (half load switch). If you dont follow these instruc your machine's life would be in danger.
Problem solved .. thanks .. we had lost our manual and had the od code .. unloaded machince .. reloaded .. works great! Altho, will say I would never buy another neptune .. we have had more problems with this washer than any in the last 38 years!
Posted on Nov 11, 2007
Beeper beeps with no error code runs ok
When does it beep? When you say it runs ok, do you mean the
complete selected cycle? Have you turned off the signal?
Do you know how to enter diagnostics? The WM0642HW does not
have a error code history file. It can only display the current error.
Aug 17, 2014 | LG WM0642H
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
I have a kenmore elite oasis HE 11027087603 and I am trying to get rid of the beeping noise that is constantly has. I know that the beeper is on console that I need to take out, but where is the actual...
This means you have an error code thats why it's beeping unplug unit remove the top and look for the servicers book this book will help you bring up the code for what was or still wrong with it.
Sep 25, 2011 | Washing Machines
Error code 49 on gw712 washing machine. constant beeping when turned on, lights 3,4 and 8 on. beeping stops once a button is pushed. If start button is pushed, lights go out and lid lock light...
Ive been told that this is a faulty cold water valve. Just got of the phone with F & P as my machine is doing the same. Bout $60 to replace
Apr 28, 2011 | Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Error code with a beeping-- reading 172 flashes
Call Kidde during business hours at the following number. I took the next paragraph off their website.
"The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you."
Nov 18, 2009 | Kidde Nighthawk Combo Gas/co Detector
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Maytag Neptune FAV6800AW Top Load Washer Logo
2,091 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
