Question about Koss KS4110 DVD Player
Can't get all cable channels available
I have charter cable but the remote will only give me up to channel 22. I don't think all the channels are selected.
  • Sean Johnson
    Sean Johnson May 11, 2010
    Wow I am suprised this dvd player gets any channels.
  • 126 Answers
Get a refund. This fault is a can of worms mate. A road you do not want to go down
Posted on Dec 25, 2008
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
Aug 25, 2011 | Televison & Video
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
Jan 22, 2011 | Televison & Video
I am using cable, no box, I want to program in the channels. The channels 1 thru 22 are already programmed but I want to add 23 thru 79 channels I can't figure it out.
The TV might have an auto programing function, which should tune in all available channels that are being delivered thru the cable/from the cable company.
Apr 15, 2010 | Samsung BN59-00455A Remote Control
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
CATV access
you need to hit the input button on your remote to CATV and u will get the cable channels
Jul 16, 2008 | Emerson TC1351 13" TV
One channel is suddently in B &W - All rest in color
is it on a cable box? try unplug tv and box, that usually resets everything
Nov 17, 2007 | RCA TruFlat 27F520T 27" TV
RCA T19064 - HOW TO GET TO MENU
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Sep 09, 2006 | RCA T13208 13 in. TV/VCR Combo
Koss KS4110 DVD Player Logo
43 people viewed this question
Top Koss Televison & Video Experts
richochet
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
