Question about Mavic Ksyrium Elite Wheelset
Under load in 12 and 13 cog chain seems to jump a tooth in 53
See above
  • 18 Answers
If your chain is jumping teeth under load, it is an indication that the chain is worn and stretched. A new chain should fix the problem, but you should also check your cogs and chain rings for wear. Your shop will have the measuring tools to do this.
Posted on Jul 01, 2009
Xv535 cam chain jumped one tooth on cog,tensioner is fine ,so how did it happen,and how can i fix it
If all cogs and bearings are fine and that the chain tension is at specification then it should not be possible for the chain to ever jump a tooth. The amount of movement required by the chain to jump a tooth is considerable. I have only ever seen this as a result of an oversight when re-installing the chain after doing upper cylinder head work such as gasket replacement. Some models of vehicles with V6 engines that integrate the timing belt with driving the coolant pump can sometimes jump a tooth if the pump bearing fails. I would again check the chain tension once the timing chain is re-installed, even without tools you should be looking for a chain that is obviously taught. Not piano wire taught as this will lead to early failure but certainly one without any slackness or rattle. I have little experience of bike engines but the principles are the same
Nov 05, 2011 | Cars & Trucks
I have a 2004 GSF600S, when I put it on centerstand and spin the back wheel slowly. There is some regular clicking sound from the transmission / gear box section. You can actually feel the click vibration...
check the tooth profile on the drive cog and the cog on the wheel
if they are more spiky that properly formed as in a new cog
then what is happening is that the pitch of the cog has altered from wear and the pitch of the chain ( distance between link pin centers ) is no longer compatible so the chain tends to ride up on the teeth and then clicks back in place
the fix is a new chain and cogs or if the teeth are good , just a new chain
Oct 14, 2017 | 2004 Suzuki GSF 600 S Bandit
Hey I bought a used Stryker about a year ago and since Yesterday i think my chain got more loose. While driving the Vehicle appears to be jumping forward, espacally bad it is when accelerating, then inside...
sounds like the chain is that loose it is slipping on the cog/s, check the cogs for wear ie no tooth damage, adjust the chainif cogs ok. better still change cogs and chain to be safe.
Sep 04, 2011 | 2005 Kymco Stryker 125
Hi, I have recently installed a new X9 derailleur in accordance with the manufactures' instructions. I have also relpaced the rear hanger. The gears shift ok, however, when in gear, especially the...
Did you also replace the chain or any of the cogs? Skipping is a common condition when you replace one and not the other. Or if the cogs and chain are well worn, it may simply be time to replace them. You can usually do fine without replacing the gear-rings (that is, the cogs by the pedals)
Nov 10, 2010 | Sram X9 Mountain Bike Rear Derailleur
My son has a Dunlop disc26 dual disk bike and the chain has come off. I can't see how to loosen it sufficiently to put it back - any ideas? The chain seems to be trapped between the bike frame and the...
To put the chain back on your do not need to loosen anything. First turn the bike over so it is resting on its seat and handle bars. Then get your fingers under the chain to one side of where it is stuck. Next lift the chain and pull it out from between the frame and the plastic guard. Now that the chain is free you will want to make sure that the chain is running around one of the rear cogs, then run the chain around the top of the front cog and slowly turn the peddles so that the chain can be fed onto the cog. It will seem very tight but will fit on just right. Then spin the peddles a few more times to get the chain find the gear it was in before the chain came off.
Jun 07, 2010 | Cycling
Engine misfires under load. smooth at idle and light load.has new wires plugs cap and rotor,
Better check the firing order carefully, and make sure your wires are completely on the plug. Check them all and push them on as hard as you can. If that doesn't solve it, check the timing. Your chain may be worn, and it could have even jumped a cog.
Oct 18, 2009 | 1995 GMC Safari
Shifting problems/Tiagra STI Flightdeck
It sounds like the limit screws on your derailleur body are out of adjustment. They are usually small phillips head screws on the body of the front and rear derailleur that limit the travel of the derailleur body on the rear so that the chain cannot get shifted into the spokes or off the smallest cog into the frame. On the front they prevent the chain from shifting off the inside or outside cogs. There are good articles under front and rear derailleur adjustments at this site:http://www.parktool.com/repair/byregion.asp?catid=53 I hope this helps.
Aug 11, 2009 | Cycling
Dodge Grand Caravan 2005 P0016 code
Im assuming it is an engine that uses a timing belt. It sounds like the belt has jumped 1 tooth. if it only jumped 1 tooth than the computer will compesate the timing so it is possible the sensors will say they are ok. If it is a motor that uses a chain than it problaly needs a new gear/chain set.
Jun 17, 2009 | 2005 Dodge Grand Caravan
Chain 'jumps' on pushbike
It sounds like your chain is either stretched or worn out. Worse case scenario is a broken tooth on the front or rear gears or worn teeth. Unless you have a chain break it is easier to take the bike in and get them to replace the chain. They will also check the rear cog and the crank at the same time.
Mar 28, 2009 | Cycling
AEG LAVAMAT 74620 Update Gears on the fill tray have jumped. The primary and idler have to be installed correctly and are fool proof but the third, half gear, needs setting. Can you please supply pic or...
Found this on another site (fixed4free.com) posted by Dave in Jan 2009:
This is one of those things where a picture would be worth a thousand words, but as I can't put pictures on this site, the words will have to do!
- Turn the orange cog anti-clockwise as far as it will go, (putting the nozzle to direct the water to the conditioner drawer)
- Look closely at the orange cog and you'll see that the last-but-one tooth at each end of the row is shorter than the rest. Looking from above and standing at the front of the machine, I call the rightmost tooth on this cog number 1, the short tooth number 2 etc. (my cog has 17 teeth)
- Position the white cog so that (looking from above) the leftmost tooth on the top (incomplete) row of this cog is between teeth 2 and 3 of the orange cog. This should be such that if the white cog rotates anti-clockwise it will turn the orange cog.
Now the difficult bit:
- The shaft that the yellow cog fits on has four vertical 'webs' running down it. Look closely and you'll see that one of these is bigger than the other three. As you would expect, if you look carefully at the centre of the yellow cog it has three small slots and one bigger one spaced around the hole.
- This shaft can be VERY CAREFULLY rotated if you pull it gently upwards against it's spring and wiggle it while twisting it. NEVER force it, the cogs underneath are VERY fragile. If it won't turn, just let go, and try again.
- Look again at the white cog, and you'll see that two of the teeth on the lower (complete) set of teeth have no slot between them, they make a tooth that is 'double width'.
- Look at the yellow cog and you'll see that it has a 'double width' slot on it's lower row.
- The challenge is to rotate the yellow cog's shaft so that you can fit the yellow cog on it, aligning the double-width slot on the yellow cog with the big tooth on the white cog. This is just a case of trial and error, but is the key to getting everything back together.
COMPLICATED BIT OF EXPLANATION!!
The yellow cog only ever turns clockwise and the white cog is a clever bit of engineering allowing AEG to move the nozzle (orange cog) backwards and forwards across the five positions.
The yellow cog turns the orange cog anti-clockwise until it runs out of teeth, then the white cog turns the orange cog the other way.
After a full rotation of the yellow cog, the orange one has moved clockwise to the stain-treatment position and the by-pass beyond, then anti-clockwise back to the conditioner position.
Apr 16, 2008 | AEG Washing Machines
Mavic Ksyrium Elite Wheelset Logo
132 people viewed this question
Top Mavic Cycling Experts
Eric Hidle
Level 1 Expert
Michial Gueffroy
numbers819
Level 1 Expert
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
