Question about AudioBahn A1451 10-Disc CD/DVD Changer
Power cable for A1451
I am installin the audiobahn a1451 in my vehicle. the a1451 comes with an 8pin DIN cable that connects to head units that have cd changer controls in the Sanyo format(Sanyo, Audiovox, Audiobahn, & Jensen). there is a cable that is available that plugs into the a1451 and has a filter/fuse box & 3 wires(12v+, 12v Acc, & ground). I am trying to find this cable. Audiobahn has not been any help because the unit is discontinued. if this cable cannot be found then will it be possible to cut one end off of the supplied DIN cable & wire it up to operate the changer, & if so what has to be done. in the supplied instructions for the a1451 there shows 4 ways to wire up the a1451. 1 shows the unit using an FM modulator. this is not an option for my install because my head unit(Valor DTS-660wt)has Aux inputs and multi-zone function. this is why i am using the a1451, for its multi-format disc reading capabilities. 2 shows the a1451 using the supplied 8pin DIN cable. again not an option because i don't have a Sanyo formated head unit. 3 shows the a1451 using a cable that has 8pin DIN on one end & 3 power wires (12v+, 12v Acc, & ground)on the other end. this is the cable i need. 4 shows the same as 3 but using an optical cable to send the audio to an amplifier with Dolby digital decoder. any help in either finding this elusive cable or a solution on powering up the a1451 would be greatly appreciated.
  • stereo69 Dec 10, 2008
    I also have the same unit already cut the plug traced it to the black (batt) and green (acc) it would load and eject the disc but nothing else ....
Yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Posted on Sep 01, 2007
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
The light on my amp is green but no sound
have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
Mar 18, 2010 | AudioBahn A2300HCT Car Audio Amplifier
It would definitely be worth your while to buy the correct cable, try Audiobahn's website for accessories.
Mar 13, 2009 | AudioBahn A1451 10-Disc CD/DVD Changer
The antenna wire for my IVA-D300 was cut off when i traded my car
the antenna plugs into the brain box there are 2 black cables coming out of your headunit one is the din cable to connect it to the brain box the other is a din cable to connect the noise filter unit
Mar 01, 2009 | Alpine IVA-D300 Car DVD Player
After replacing the battery in the car, the multi cd player is not working
Check the manual for reset procedure (button?) or. Make sure vehicle is turned off ,unplug din cable and power ( plug or fuse).
Turn Vehicle and Head unit on and off,
turn off key, replug and try.
If that fails contact the manufacturers support Dept.
Regards, paul
Jun 22, 2008 | Pioneer Car Audio & Video
JVC XV-THC4 Home Theater System
it a 8pin din cable ,,,,I picked up one from a specialty cpu shop in Norcross,Ga
but search ""8pin din cable"" see what you find!!!!
the power cord is extremely common ,you can find that one anywhere ,,,,,most any dvd player ,playstation etc etc etc uses that cord
Sep 17, 2007 | JVC THC4 Home Theater System with 5-Disc...
Amp Problem
my first thought would be the rca's. make sure the rca's are in good condition and also make sure that their in the right spot from the head unit. (some head units have multiple rca outputs or inputs) and be sure that your gains and levels are all set right
Sep 12, 2006 | AudioBahn A4601T Car Audio Amplifier
AudioBahn A1451 10-Disc CD/DVD Changer Logo
207 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
