Question about Dell Dimension 8250 PC Desktop
On boot up lines appear looking like zip code bars
I also get these line on my cursor.
    Master:
  • 568 Answers
Try cleaning the ram
Posted on Dec 25, 2008
  • 191 Answers
This is the problem with display memory which is on the vedio card or on the motherboard. you may try
1) change RAM memory on the motherboard and test, go next if not solve.
2) install the new vedio card (AGP OR PCI) if build-in vedio used before test again
3) change a vedio card if the vedio card(AGP or PCI) installed before
Where do these anonymous shortcut bars come from?
You may have a program like UltraMon installed
Suggest you look for Ultramon and uninstall it
You may have to Google 'UltraMon alternatives' and see if they show up in your program files
Feb 12, 2015 | Computers & Internet
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
Monitor comes up black i can see the cursor but nothing else any ideas? it boots normally but once past the boot screen its all black with just the cursor showing
Nevermind the more I thought about it, your not getting to the operating system. The PCs used to say something to the effect of 'operating system not found' after the POST if it could not find a boot device. I think that's what's happening here, you have to go into to BIOS and see if it can detect the hard drive. When the laptop boots look for a message saying 'press F1 for setup' or something along those lines... if it comes up too quick to see start hitting F1, Esc, Del keys right after the power lights comes on, BIOS is usually one of those keys. Once in BIOS look for a 'devices' type tab and search for where it reads the hard drive If there's nothing there then its your problem, and you need to get the BIOS to autodetect it. Respond if you have questions.
Jan 11, 2012 | Toshiba Satellite A215-S5818 Notebook
The lcd had a half-inch line from the start menu bar. it bothers me from reading any file. do i need to call the service center for the check-up? thanks
You may have expanded you menu bar inadvertently. Place cursor over the top edge of bar, left lick mouse or track pad and slide cursor down, bar size should be reduced. Good luck
Dec 24, 2010 | Compaq Presario 700 470024-192 Notebook
Immediately upon boot, vertical lines appear on screen. After several minutes the screen turns pick and the windows cursor appears. there is no further change in the display. Mouse appears to work. Not...
My first check would be video drivers if this is a newly built computer. If it is a computer that has been running a while and the problem suddenly appeared I would reseat the RAM and attempt to boot into safe mode, suspecting a virus infection.
Mar 01, 2009 | HP Computers & Internet
Macromedia dreamweaver to crate menu bar
  1. Load your index.html page as before. That is, doubleclick the file in the Files pane in the right column.
  2. Locate your existing navigation menu, which at this time merely consists of a series of links to your home page, About Us page, Contact Us page and the Site Map. Select them and delete them. We will be completely replacing them in this chapter.
    1. Make sure that the blinking text cursor is currently in the side bar. If it is not, click somewhere in the side bar. Now click "Insert | Spry | Spry Menu Bar" from the menu. That is, click the "Insert" menu, then the "Spry" item on the menu that appears, and finally on "Spry Menu Bar" on the submenu that appears.
    2. A dialog box will appear asking you whether you want a horizontal menu bar or a vertical one. Since we are placing the menu bar in the left column, we want a vertical menu bar. Select the "Vertical" option and click OK.
    3. A default menu bar will be inserted into your side bar. If you look at the Properties pane at the bottom of your Dreamweaver window, you will see that the text and links for menu items are displayed there.
    4. Select "Item 1" by clicking on it, if it is not already selected. In the "Text" box, replace the words "Item 1" with "Home" (without the quotes). Replace the default "Link" text of "#" with "index.html" (without the quotes).
    5. By default Dreamweaver created a submenu for your menu. We don't need one, so we will need to delete it. Select "Item 1.1". Directly above "Item 1.1" are two buttons "+" and "-". Click the "-" item to delete Item 1.1. Do the same for "Item 1.2" and "Item 1.3".
    6. Now do the same with the other items, replacing the text with the appropriate words for your site, and the links with the actual page names. If there are submenus, delete them as you did for Item 1. For your convenience, the replacement text and links are reproduced below from chapter 3. Note that Item 3 has a three-level menu system. Delete all submenus (item 3.1.1, 3.1.2, 3.1, 3.2, 3.3) - we won't need them.
      • Text: About Us, Link: aboutus.html
      • Text: Contact Us, Link: feedback.html
      • Text: Site Map, Link: sitemap.html
    7. Click "File | Save". A dialog box will pop up telling you that certain files have been added to your site, and that these files will need to be uploaded. Click "OK".
    8. Now upload the page to your website using "Site | Put" and check the results in your browser. Hover your mouse over your menu buttons, and you will see that they change colour.
    Customizing the Spry Framework's Menu Bar Widget While adding the Spry Framework's navigation menu bar to your web page is a simple procedure under Dreamweaver, customizing it is, however, another cup of tea. There is no built-in method to do so under Dreamweaver's user interface. You will have to do it manually.
    The fastest way to do this is to do it via Dreamweaver's "Code" view.
    Dreamweaver has two basic ways you can work on your website. So far, you have been creating your site using the "Design" view. The "Design" view allows you to work on your web page using the What-You-See-Is-What-You-Get (WYSIWYG) editor - that is, as you create your web page, you basically see the page as a visitor would when they visit your website.
    The "Design" view hides the real code, the HTML and CSS code, that Dreamweaver generates for your website. This code, the "raw" code, if you will, is the actual content that is uploaded (published) to your website. When your visitor loads your web page, the browser takes the "raw" code and displays it according to the instructions given in the "raw" code.
    To customize the Spry Framework's menu bar widget, you will be using Dreamweaver's facility for viewing this "raw" code for your website. Even if you find the menu bar widget satisfactory at the moment, you should still take the following steps to familiarize yourself with Dreamweaver's "Code" view. You will be using the Code view in a future chapter to insert your feedback form code.
    To switch to the "Code" view, click "View | Code" from the menu. Instead of the web page that you are accustomed to viewing, you will now see the "raw" HTML code for that page. If you scroll up and down the page, you should be able to see your content amidst other characters. These other characters, things like "<p>" and the like, are the formatting code that tells the browser how it should render your page.
    Centering the Menu Bar Scroll to the top of the index.html file in "Code" view. Locate the text "</head>" (without the quotes) somewhere near the top of the file. Place your cursor just before "</head>" on the same line. Hit ENTER (or RETURN) to insert a blank line. When you do this, the entire line with "</head>" should move downwards, creating a new blank line. Move the cursor to the blank line.
    Now copy the text from the box below and paste it into the blank line you just created in Dreamweaver. To copy the text, select all the text in the box with your mouse, click the right mouse button (or if you use Mac OS X, hold down the Control key on the keyboard and click the mouse), and select Copy from the menu that appears. To paste it into Dreamweaver, switch to the Dreamweaver window. Make sure that your text cursor is in the correct location (in the blank line above the word "</head>"). Select "Edit | Paste" from the menu. <style type="text/css">
    ul.MenuBarVertical
    margin: 0 auto ;
    width: 8em;
    </style>
Jan 22, 2009 | Macromedia Dreamweaver MX 2004
I bought a "Living Solutions" Brand Universal Remote to control my SONY tv. It lacks a (Code Search) Button. It has a INPUT tv-vcr button, OK button and a button that looks like a speaker with a...
For the Item: Living Solutions Colossal 3-in-1 (606426)
Look in this link (it's the manual for the remote). It may help. Just copy the link to the address bar & download the file. It's a zip folder.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
May 03, 2008 | Televison & Video
Wii console...cursor doesnt appear on the screen but everything is sychronised and buttons on remotes work?
In the Wii settings make sure that the sensor bar setting is correct wheather it is top or bottom of tv. Then make sure the sensor bar is as far font as you can get it to give clear line of sight to the controller.
Apr 28, 2008 | Video Game Consoles & Games
Dell Dimension 8250 PC Desktop Logo
59 people viewed this question
Alun Cox
