Question about RIM BlackBerry? Curve 8330 Cellular Phone
Appears to record but won't playback/rename/save
It appears to be recording but will not play back. When I go to ''rename,'' it says ''The selected file is read-only. Would you like to save?'' When I choose ''Yes,'' it responds with ''File not found.''
    Problem Solver:
  • 5 Answers
Gainus,
Check how you have the BB set up to save the files...... read only's are just that... read only... you can't manipulate, rename, move etc them period. Set your recordings to save in another format. That just might solve your problem. Merry Christmas!
Posted on Dec 26, 2008
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
Playback problem
Have the same problem.  This is what I have found in trying to solve the problem.  It appears that it is a tracking problem and it appears that either your new "used" camera has the problem or your original camera had the problem.
A simple test would be to take another camcorder and see if the tapes play. If they do, and a recently recorded tape DOES NOT, you may just need to get another camera. Or, see if the camera can be re-tracked at a repair shop. However, be sure you have copies of your most recent tapes recorded with the bad tracking
Feb 09, 2009 | Activision Soldier of Fortune: Pay Back
No recording occurs when in record mode
If the red light does not blink while you speak, then the internal microphone is bad or a wire has broken off. If it is blinking, the record playback changeover switch is bad. This part is difficult to replace. Repair cost should be around $75.
Dec 28, 2008 | Philips Audio Players & Recorders
My new RCA Model 25205RE1-1 1815MO does not want to record a OGA. It appears to be recording as it so states and counts the seconds as you are speaking. I press EXIT and the OGA is not played...
The RCA Manual in incorrect. Step 8 reads "Press Set/Save to start recording. Speak within 6 inches away from the Mic located under SPEAKER button." Step 9 reads "Press EXIT to stop recording." Step 10 reads "The OGA is played automatically for your verification. It will then return to the OGA REC menu to start over or to record another OGA."
Step 9 should read "Press Set/Save to stop recording and the OGA is played automatically for your verification."
Step 10 should read "Press EXIT if recording is acceptable. Press Set/Save if you want to re-record."
By following the Manual you never save your message. "Playback" always has the Default message that comes on the machine. Furthermore, Customer Service at 310-953-9028 doesn't have a clue.
Jul 01, 2008 | RCA Lands Phones
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
RIM BlackBerry? Curve 8330 Cellular Phone Logo
Top RIM Cell Phones Experts
ismael castillo
George Etukudo
George Etukudo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
