Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
Lost password to siemens gigaset se587 wlan dsl
Hi I am trying to add my daughters new laptop to my existing wireless network but I cannot access my router admin as I have lost my password and dont know how to retreive it can anyone help please?
  • 1 more comment
  • john28933 Feb 23, 2009
    don't know password for router
  • Anonymous Mar 23, 2009
    I can't reset my gigaset gatway
  • eecom May 11, 2010
    Hi....you need to reset the router to restore the default password/s. Please note though, this will remove all your settings, and you will usually need to set up your internet connection again.
    The reset button is usually a tiny pinhole which may be unmarked. A Siemens manual for a different router model says it is behind an opening on the base of the device - it may be the same for your model - unfortunately I don't have a manual so can't be more specific. :) If not, try the back. You have to press the reset 'button' with an unravelled paperclip for 5 seconds, sometimes more, to return to factory defaults.
    Once factory defaults are restored, I think the default password is admin. This should get you back in so you can reconfigure your router. Good luck..
  • 3 Answers
You can try to google password genius
Posted on Sep 03, 2010
I have just bought a wireless enabled Laptop and already have two desktops in network using Tiscali through siemens gigaset se587 wlan dsl. Is this a wireless router and will I be able to connect my laptop...
yeas you should be able to as long as you know the passkey to connect to the router. windows should detect the wireless netowork automaticlty and you just select to connect
Feb 02, 2010 | Computers & Internet
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Short operating range of wireless router
Hello Peter. I think you may have pinned down the problem within your post. British brick walls can be very solid - and thick - which may well be enough to degrade or block your wireless signal.
The first thing I would try is to move the router to as open and central a position as you can, and see if that helps. Adding a wireless LAN antenna to your router can also help boost a weak signal a little (these just replace an existing antenna on the router).
However, other options you may want to investigate include:
1) using a wireless repeater to boost the signal from your router;
2) a powerline networking system, such as Homeplug ;
3) installing a new router with a more powerful range
..or indeed, abandoning wireless altogether and using a wired connection!
I hope this helps you explore some options, and find a solution.
Nov 15, 2008 | Computers & Internet
Siemens Gigaset SE587 WLAN dsl - Firewall
It does have a firewall but I have no idea how effective it is.
Sep 21, 2008 | Computers & Internet
I just recieved my Siemens Gigaset SE587 WLAN dsl router and i set it up but the only light coming on is the power light,is the router faulty or damaged?
Are all the cables connected correctly?
Are the DSL settings in?
If it's only the power light, and no WLAN, LAN, DSL or Internet lights on, it sounds like it may be faulty. Is it brand new or second hand?
Aug 22, 2008 | Siemens Computers & Internet
Tiscali Siemens SE587 router
I have solved my problem, after researching various messageboards yesterday to try and discover why my Siemens Tiscali router didn't work. I'm going to send it back and go with another company!
It seems there has been a lot of debate on these messageboards about Tiscali and/or Siemens products and it now seems also that no one would recommend them. I hereby add my name to that list.
Aug 19, 2008 | Computers & Internet
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless internet
The other unit needs a wireless adapter to talk to the router wirelessly
make sure that the wireless function is turned on in the router software ,
you need to enter an IP address in the internet explorer to get into the router, (this should be in the manual or printed on the base of the unit).
you will need to enter a user name and password, (read the manual for these), sometimes, admin admin ,or admin password)
if you used a security key, make sure it is in the wireless software, of the wireless pc/laptop
good luck
Terry
Mar 25, 2008 | Computers & Internet
Error #105 TCP connection to the server timed out.
IMPORTANT NOTE: If you have received this error, you are not using the latest RealPlayer. RealPlayer 8 Basic is a FREE, recommended update available for Windows 95/98/NT and recent Macintosh systems.
If your system meets the minimum system requirements, it is recommend that you update your player.
The attempt to connect to the TCP server took longer than allowed. This problem may be caused by a high network load (i.e. too many people on the internet) or the server maybe down.
If the load is too high, you may try later or you can increase how long your computer waits by changing the Network timeout values under the Connection tab in the RealPlayer Preferences. If the server is down, the only solutions are to try a different server or contact the server administrator for the site you are trying to access.
Mar 18, 2008 | SMC EZ Connect Wireless Networking Starter...
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
9,373 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
