Question about Nintendo Wii Console
Remotes won't turn on
The Wii turns on but the remotes won't it will only blink but never turn on and i already changed the batteries.
  • 73 Answers
Ok,you changed the battery already but did you synchronize the remote to the console?beside the battery of the remote is a small red button.did you try to press this button? as well as the red button on the console?it is located on the memory card port of the wii.try it first,let me know
Posted on Dec 25, 2008
    Problem Solver:
  • 3 Answers
Try turnin off the console and using the 1st controller press the power button... this should turn the console back on and the lights should flash if the blue light doesnt fill the 1 square press the power button again and sometimes it will turn on the remote but maybe not... this is only thing i can think of
4 Suggested Answers
  • 7 Answers
SOURCE: wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
Posted on Jul 21, 2009
meeknotweak
  • 341 Answers
SOURCE: wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Posted on Aug 21, 2009
DD1992
  • 122 Answers
SOURCE: 2nd wii remote permanent low battery
the problem is the remote itself not the battary take it back and get a new one.
Posted on Aug 23, 2009
Wii remote won't sync
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This sync procedure must be followed for each additional Wii Remote added to the system.
Mar 08, 2012 | Nintendo Video Game Consoles & Games
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
I have 2 wii remotes that have brand new batteries in them but everytime that i try to turn them on the blue light just blinks and turns off and i have already tried to sync the remotes with the wii but...
If I remember correctly, you can't just turn them on without being in a game. See if you can start a game, then press the home button and sync the with the wii by holding down 1 and 2 together.
Jul 18, 2011 | Nintendo Wii Remote Controller
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Jan 27, 2011 | Nintendo Wii Console
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
Wii remote lights blink but it doesn't turn on or work
Turn The System on and open the slot next to the disk tray Then press the red button after that open the battery.Don't take the batterys out but press the red button next to the batterys.That will get you syncronized and you wiil never have to connect the remotes the old fashion way.Just press 1 and 2 when the console turns on and you wil be ready to play.
Jul 06, 2009 | Nintendo Wii Remote Controller
Nintendo Wii Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
