Question about RC Thomas the Tank Engine
Where do i plug the charger into
We bought a slightly used ride on thomas and we dont know where to plug the charger in
  • katnluvr Dec 31, 2008
    where under the seat? i also bought a used one and can not find where to plug it into
  • Anonymous Mar 28, 2014
    the charger light stays on green even when charging? and now it will not work
    New Friend:
If its the one that comes with rails there's a round hole connection similar to a mobile phone charger connection at the back or side of engine I believe it's by seat somewhere
Posted on Jan 17, 2013
  • Bill Apr 08, 2013
    That is exactly where it is. Thanks for your help
  • Bill Apr 10, 2013
    How do you repair or replace the motor the train will play music but will not run. Thanks
The battery is probably located under the seat and will plug in there
Posted on Dec 26, 2008
Need tracks for ride on thomas the tank engine
Ebay would be where I would go for this.
Jan 21, 2013 | RC Thomas the Tank Engine
Water damaged ride on thomas the tank engine.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 27, 2012 | RC Thomas the Tank Engine
My Thomas the tanks engine ride on won't hold it's
check the charger with a multimeter and make sure that its putting out the correct amount of volts
Jun 09, 2012 | Toys
Thomas electric ride on will not charge
Here are a few things to check - Is your battery charger plugged into a known working outlet? Is the charger plugged into a switch controlled outlet? Is it ON? Have you checked the output voltage of the charger with a volt meter? The in and out voltage should be molded into the charger housing. Is there any internal damage? Are you sure the battery is connected to the wires inside? Is the motor connected through the controller? Is there a fuse - have you checked it? Is the ON/OFF switch in the on position and is it actually ON? Check with a Volt/Ohm meter to be sure. How old is the battery? Can you check its voltage? Expect 1 to 2 years use only. If you get more, well you got more ... good. If it is older, that may be the problem. Volt Ohm meters available for around $10.00 at hardware and electronics stores. All come with basic instructions.
Thanks for your question @ FixYa.com
Nov 09, 2011 | RC Thomas the Tank Engine
Have lost charger 4 ride ad go thomas will any 6v charger fit it and where do u charge it anyway is it the hole at the back of the train
It looks like the charger has a specific plug terminated on the end so I would suggest buying the manufacturers replacement part. It can be purchased in the UK from the below links for around £35 or slightly cheaper form ebay but from a seller in the USA (third link below).
The charger model number is MECB0037.
http://totcars.co.uk/detail.aspx?ID=848
http://www.pedalpusherslimited.co.uk/pedalscat/peg-perego-replacement-6v-charger-p-515.html
http://www.ebay.co.uk/itm/220796543022
Hope this helps.
Aug 04, 2011 | Peg Perego IGED1084 Santa Fe Train
I bought an MPV5 used. Batteries won't charge. Charger light is green after 24 hours...slight power surge then dies. The seller said it hadn't been plugged in for a long time. I also noticed the batteries...
Lets solve this, one question at a time ....
First your batteries are not charging,This may be because of it siting for too long without a charge.The batteries may be so dead that your charger cannot reconize them. dont losse hope there are ways to check your batteries and charger with out spending alot of money on a tech coming over.
1) Unplug and remove your batteries from the chair
2) Find your self a charge that trickle charge
(Note: If you have a batterie charger ,trickle charge is the lowest set charge)
3) Trickle charge each batterie to about 50%
4) Install batteries back on to chair
5) Plug in chair charger
The chairs charger should come on ,and that right there tells you that you have a good charger!
The batteries that came with this chair are not bad and are considered ok to use .These type of batteries are what you call maintenance batteries ,which your always having to check if the leaking or need water.The gell type batteries are what they call non-maintenance.That you dont have to always look after but are more money.Thats why they recommend the gells so that the user doesn't have to work on there chair.
I hope that was helpful ,Happy Riding
Feb 10, 2011 | NRS Hoveround MPV 5 - Used Power...
Need a battery charger for thomas the train ride on
you can get one on ebay for about $6 shipped, just look for a 6v1a sla charger
Nov 24, 2010 | Peg Perego IGED1084 Santa Fe Train
I was given a thomas train and track set, but did not come with battery or charger. I need to know which ones to buy.
well youlle realy need to buy the batteries that could fit and move into the toy you bought. also if the battery you used dindt work. maybe you should try a medium sized battery.
Apr 07, 2010 | Learning Curve Toys Thomas the Tank Engine...
Need Diamec 6V 4.5AH battery charger for Thomas the Train
Call peg perego directly. You want to make sure you get the correct one , you can mess up the battery with a slightly different charger.
Jan 12, 2009 | Peg Perego IGED1084 Santa Fe Train
RC Thomas the Tank Engine Logo
1,040 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
