Question about Dell Latitude C800 Notebook
Wrong power supply
I have a Dell C840 2 ghz laptop running XP Pro which requires a 90 watt power supply . I have one that works fine. My son has a C840 1.1 ghz which uses a 70 watt power supply. He tried plugging his power supply into my machine while Windows was running and it caused a message to appear on my laptop which said that a 70 watt power supply was detected and that the machine would only run in battery optimum mode until a 90 watt power supply was used and to press any key to continue. On pressing a key my machine's monitor went blank and it locked up. I had to hard-power the machine off (held the power button for 5 seconds) then restarted with my 90 watt power supply. The problem is that I continue to get the message on startup, but with an option to press F1 to continue, which it will go ahead and boot up, but my batteries won't charge anymore. I have completely disassembled the machine (including disconnecting the cmos power supply) and reassembled several times, but I still get the message, and the batteries still won't charge. Once, after following this procedure the machine booted without the message and the battery light was flashing indicating that it was charging. However, after I disconnected and reconnected the power supply, the same old message popped up and the machine locked up after hitting any key. I suspect that it could be the onboard battery charger, but before I start looking for one I wanted to put it before the experts. Any suggestions would be helpful. Thanks
  • 1 more comment
  • Darryl Crouch Apr 17, 2007
    I read on the internet where someone who seemed to be having the same problem removed the batteries and AC power and held down the Power button for 1 minute to clear the NVRAM. I tried it, but that didn't work either. I started swapping parts from my son's machine with mine, battery charger, video, etc., but still get the same error. Someone at work has an C840 they have been canibalizing for parts and the MB is still in it. Since that's the only thing I have yet to swap I'll try that tonight and see if the problem is there.
    I reflashed the BIOS last night to no avail, but thanks for the suggestion.
  • Darryl Crouch Apr 18, 2007
    Changing the motherboard did the trick.
  • MajickMan Dec 23, 2007
    we have a C840 with a universal Targus 90W universal power supply after the original burned out and started to smell. Used a 70W for a couple of days while waiting on the 90W to arrive and now the 90W powers off when plugged in and the 70W won't charge the batteries. Anyone got any ideas other than replacing the motherboard which would not be cost affective solution.
Hi. to me it sounds like you have blown something . Try replacing the battery or reinstall windows. If that doesnt work sorry but i dont know anything else :(
Posted on Aug 24, 2010
Rerset the bios option for the battery / power performance
Posted on Apr 08, 2008
  • 60 Answers
It sounds a little overkill but it really sounds like a cmos problem. try flashing your bios if you cant find the power options in the bios. you like to try setting the cmos to default values.
Posted on Apr 16, 2007
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
Dell d 600 laptop is working perfectlly on dirct power supply but not charging the battery
If the battery is the original one than most likely the battery will need replacement.
If a new or known good battery will not change, while using a 90 watt standard ac adapter (An Auto Air adapter will run the system but not charge the battery) then next is motherboard replacement
Dec 27, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
My Dell610 laptop says that it can not recognize
you need a 90 watt power supply,the one you have is bad
Sep 05, 2009 | Dell Latitude D600 Notebook
Dell inspiron 1521 laptop won't recognize a new 90 watt power
There are different types of Dell power adapters, some of them put out different amounts of power. While it is possible that the battery is faulty, it is more likely, given your error message that the adaptor is wrong. If you got it from Dell, you can call them and they will exchange it.
Jun 21, 2009 | Dell Inspiron 1521 Notebook
What power supply is required. The rear input
No. It is not recommended to use this power supply, since it outputs only 12 watts of power, whereas the required power to run your speakers is 26 watts.
You will have to use a power supply which outputs 13 VDC, with at least 2A.
May 16, 2009 | Altec Lansing ACS 90 Computer Speakers
Soyo motherboard k7vem
No. The K7VEM pro motherboard supports only AMD CPUs. The maximums are as follows:
Up to Athlon XP/Palamino 1800+
AMD Thunderbird 1.4 GHz
AMD Duron 1.3 GHz
The preceding information was taken from Soyo's website. Here is the link for the cpu support page.
Thanks and please take a moment to give this a good rating since it answered your question and rate as fixya. Thank you.
Dec 24, 2008 | Soyo K7VEM Pro Socket A Barebone with 300...
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP DV9000 Display Works with battery not AC almost
Have you checked whether the Power Adapter of your Notebook is a 65 Watt or 90 Watt ??
If you are connecting a 65 Watt adapter with the Notebook, try wiht a 90 watt one from any other Notebook if available..
Notebooks with Nvidia Graphic card need a 90 Watt Power adapter to supply the adaquent power required for the Graphic Card and a 65 Watt adapter may not be able to supply the required power.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
Dell Latitude 500 - Battery vs Power Supply Problem
As far as which adapter to use, either should work fine. The 90 watt will run cooler. I have seen the 65 watt go up in smoke when being used on a continuous basis.
As to the battery not charging, unfortunately, it sounds like you may have a problem with the internal power supply. The orange light is showing that the battery is discharged. If this light doesn't turn green after the laptop has been plugged in for a couple of hours, you are not getting the battery charged. Power the laptop down, remove the battery. Check the contacts on both the battery and laptop battery connector for any foreign material or "Gunk" and for any bent or broken contacts.
Hope this helps!
Nov 03, 2007 | Computers & Internet
Vista to XP downgrade
If you did a clean install of Windows XP Vista has nothing to do with this problem. I infrequently have problems with Dell drivers not working but when I do its because I've installed the wrong ones. I have gone down the wrong troubleshooting path several times because the driver said it installed correctly..... I noticed that when you go to the Inspiron 6400/E1505 download page ( you have the choice of selecting drivers from lots of OS versions including both 32 or 64 bit versions of XP. I would verify that you have the write driver versions and try again. Another alternative is using the drivers and tools CD that typically comes with a Dell. You can run that and it should have XP drivers. If you don't have the disk you can also try getting the network card running, connect to the Dell site and running their driver ID wizard to ID the drivers you need. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 20, 2007 | Dell Inspiron 6400 Notebook
Open Questions:
See all Dell Latitude C800 Notebook Questions
Dell Latitude C800 Notebook Logo
198 people viewed this question
Alun Cox
