Canon printer pixma ip1200
The printer has been flashing some lights. It occured an error either ink cartridges are not recognized or it needs to be installed. I have already checked both cartridges and both are installed properly..is there some sort of disconnection which I could not see nor detect?
Thank you.
  • 1 more comment
  • lightfeather Jan 01, 2009
  • Ethel Red Jan 31, 2009
    Just installed a new PG-40 black cartridge in my canon pixma ip1200 and I get the message that the cartridge isn't recognised when I try to print. The orange paper feed light is flashing five times then the power light flashes once. I read on another website that this cartridge and others like it will never work because they carry a chip designed to cause this problem. True or not? I don't know. Every one makes mistakes, but this seems like a nice little earner for canon. Sorry I couldn't help.
    Eth
  • rokfort Mar 23, 2009
    I too have the same problem. Just installed a new PG-40 black cartridge in my canon pixma ip1200 and
SOURCE: paper detection and new ink cartridge
Press the green diamond key on the face of the printer when the error message comes up and it will print
Posted on Feb 18, 2008
SOURCE: PIXMA iP1880 ink cartridge not properly installed....
after refilling the cartridge printer shows error.The green and yellow lights alternatively
Posted on Oct 13, 2008
joenie1975
  • 22 Answers
one solution is turn off your printer, and reboot your system, after rebooting, turn on your printer again. If that doesn't work try re-installing the printer drivers be sure to turn off the printer and reboot the system afterwards to refresh the system.
Hope this was helpful:)
Posted on Oct 19, 2008
  • 104 Answers
SOURCE: new ink cartridge not recognized
Please check if there is not some dirt, or something blocking the contacts from reading. Also the ink level is measured by optical sensor that can also be dirty.
Also make sure you use an Original Canon cartridge.
Posted on Feb 28, 2010
  • 120 Answers
SOURCE: my canon pixma ip1200 printer
Replace a new cartrige. Then try to reset printer absorver permanently-
1.First, download the resetter software that the user majorhazard let the link.
(http://canontips.blogspot.com/2009/02/canon-pixma-ip1200-ip1600-ip2200.html here`s the link by the way.
2.use the regular steps to reset temporal,unplugged the cable, press and hold the power button, reconect the power cable, while holding the power button, press reset button 3 times, turn the printer on.
3.here are the another steps to reset permanently
1.uncompress the Generaltool.exe
2.Run GeneralTool.exe
3.select the USB PORT of the printer
4.hit or click on LOCK RELEASE
5.check the checkboks CLEANING and also EEPROM CLEAR
6.click in the model of printer (My case IP12000e)
7.Click MAIN and PLATEN
8.Click TEST PATTERN 1.
9. that`s all.
10. If you wanna be sure that works just unplugged the printer and reconect(Power cable.)
Thank you
Posted on Jun 16, 2011
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
I wanted to print my documents here but my printer always says that the ink cartiledge is not properly installed and i already reinstalled my canon printer pixma ip1200
Make sure the ink cartridge is properly installed. Or this is probably common problem with Cannon ink cartridge, replacing the cartridge will solve the problem, but you need check it first under maintenance on Control Panel.
Aug 06, 2011 | Canon PIXMA iP1200 Photo Printer
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Black ink cartridge.
the printer only prints with all ink cartridge inside, back and color (use only original ink spares)
Dec 29, 2009 | Canon PIXMA iP1200 Photo Printer
Problem with my canon printer ip1300
You can try this it works for my 1500 printer.
Go to the printer settings and turn off the ink low messages.
Switch your printer on and hold the paper feed switch down for the count of five the orange light should flash. Then switch off the power and switch back on again the green light should stay steady. If you do not come right on this one you can email me at grayjem@mweb.co.za
Aug 10, 2009 | Canon PIXMA iP1300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
402 people viewed this question
jasbo
jasbo
