Question about Microsoft Windows XP Professional
Windows operates very slowly
Even thought I ran Disc Cleanup and then Defrag, the system operates better but still very slowly. For instance, when I launch IE, it takes a minute or so to let me see the browser. What to do?
  • scott011 May 11, 2010
    What os. are you running? And I need some spec. of your pc.
It could be too many startup apps in Msconfig, not enough memory, need to run Volume Check, need to run defrag, bad spots on hard drive, spyware.
Posted on Dec 25, 2008
Tip
Top 7 Tips for Windows 7 Maintenance
Want to keep your Windows 7 running as fast and stable as new? Updating hardware configuration and protecting your PC from being attacked by virus and spyware is indispensible, but, that’s not enough, even with the "impressive/promising" Windows 7.
Well, there is no rose without a thorn. For enjoying the non-compromised features of Windows 7 and keeping its freshness as long as possible, you can take the following top 9 tips for Windows 7 maintenance, and save your time, money as well as get full control of your PC!
Windows 7 Maintenance Tip 1: Cleanup hard disk
Windows temporary files, internet cache, cookies, invalid shortcuts and unused files and programs can take up much room on your hard disks. Even you have just upgraded to Windows 7, those junk files can soon accumulate and eat up hard disk space. So regular disk cleanup should be part of your Windows 7 maintenance routine.
Windows 7, as its predecessors, has a built-in Disk Cleanup program, you can find it in Start>Accessaries>System Tools>Disk Cleanup.
Windows 7 Maintenance Tip 2: Defrag hard disk
Your hard drive can be full of fragmentation with time, which dramatically slows down Windows running. Microsoft OS including Windows 7 provides the built-in Disk Defragmenter tool, which lets you remove empty patches, pack pieces of files together, and thus occupy contiguous storage locations, increase the speed of reading and writing files to/from hard disk.
Frequency: Disk defragmentation should be performed every two or three months, because frequent disk defragmentation can decrease the span of hard disk.
Windows 7 Maintenance Tip 3: Speed up Windows 7 boot
Open Run, input “msconfig”, then select “Boot”, you will see a list of programs in that auto-start folder. You can manage them there.
Windows 7 Maintenance Tip 4: Scan and repair registry
Registry is the central database of Windows which stores the necessary information and settings for software and hardware running smoothly. Even you have uninstalled a program, respective information is saved there. Windows registry can be full of errors that cause the main system crashes, error messages, freezes and slowdown. You will be amazed when you view how many errors exist in your registry.
Microsoft experts never suggest people to manually change their registry, since any improper operation to registry can cause serious damage. Instead of taking that risk, using a third-party safe Windows registry optimizer might be better. You may refer to this article and learn .
Windows 7 Maintenance Tip 5:Defragment registry
Just like hard drive needs defrag, registry needs too. Registry defrag is to remove fragmentations and creates a linear registry, which can speed up registry access and program response. Some defragger also compacts your registry to a smaller size, thus it can take up less memory and make room for other programs running fast. There is a free registry defrag software which can safely defrag registry in two minutes for most Windows systems.
Windows 7 Maintenance Tip 6:Uninstall unused programs
Uninstalling programs that you seldom use is better than just removing them from your hard drive., because simple deletion can cause Windows errors. Some programs have the built-in uninstall app while others don't. Then you can go to the control panel and uninstall them. For those malicious programs that don’t allow you to uninstall, you can make use of a third-party uninstall manager (known as built in Wondershare Registry Optimizer) to get rid of them.
Note: cleanup registry is necessary after the uninstallation. Detail is given in the following part.
Windows 7 Maintenance Tip 7: Boost performance by adjusting registry parameters
This step is to change registry parameters designed to boost Windows 7 system performance, such as automatically end hung applications, optimize internet connection, speed up loading web pages, speed up Windows shutdown, etc.
There are many online tips talking about how to manually revise registry settings for better system performance, but manual revisement fits more for computer expertsor than for beginners. Beginners has better use a system optimizing utility (known as built in Wondershare Registry Optimizer) to have this done in single 1 mouse click.
on Dec 23, 2009 | Computers & Internet
Cant defrag because it says it cant because disk cleanup is scheduled on next restart I did not schedule one but when you restart it says cleanup has been cancelled...help
Simply download a PCFresher and defrag your OS by using its Deframenter feature with one click. Its a very reliable program am using it since 2011.
Sep 04, 2013 | Microsoft Windows XP Home Edition
My computer work very slowly it doesent respond to my order fast but so slowly when start up ,go on net >>>>>i want to run repair on line please send me the linkn>>>>>my...
Hello there,
Initially, you can do a disk cleanup and disk defragmentation. Go click on Windows Start >> All Programs >> Accessories then System Tools. Disk cleanup will delete all uneccessary files in your computer. Disk defragmenter rearranges files stored on the computer making it load easily.
You can also do a free scan by clicking on the link below.
http://eset.com/onlinescan
Jun 02, 2011 | Computers & Internet
My computer can't defrag, it just runs for hours on end.
I haven't used the default defrag prog in windows for a long time but it was always known to take forever if regular defrags had not been performed.
This will be the case for any defrag prog. however there are faster ones out there. Try the following free one and defrag weekly.
http://download.cnet.com/Auslogics-Disk-Defrag/3000-2094_4-10567503.html?part=dl-6267754&subj=dl&tag=button
Apr 28, 2010 | Microsoft Windows Vista Ultimate Edition
Computer takes longer to boot up, plus is running very slow
1. To increase PC boot speed:
There must be too many programs automatically start when you boot your PC. To manage them, click Run, type in "msconfig", select "Boot", then you can disable unnecessary programs from that list.
2. To increase PC running speed:
* Adding RAM is the most effective method, but if the RAM is already at the maximum, then do the following.
* Run disk cleanup and defragmenter. But to be honest, the built-in Disk Cleanup and Disk Defragmenter run quite slow and they will take you quite a long time, so I never use them. Third-party programs are better.
* Run registry optimizer software and defrag. No Windows built-in tools to do this. Search on google or refer to this free registry cleaner review.
Jan 11, 2010 | Toshiba Satellite M65-S821 Notebook
I use photoshop elements 7 on windows vista and recently got an error message saying it has stopped working... any suggestions?
Photoshop did the same for me. What I did was a system cleanup. Ran disk defrag after that and it worked fine. Having too much clutter effected my experience. Once done it ran fine.
Jul 06, 2009 | Computers & Internet
Disc d is almost full. Processing is so slow. How do I free-up space on d?
Defrag, Dis Cleanup ,removing unwanted software,buy another har drive,partionise your hard drive.
Hope this helps if you need more please post.
Apr 17, 2009 | Microsoft Windows Vista Home Premium...
Microsoft Windows XP Professional Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
