Question about Acer Aspire T160 (AST160UA3400) PC Desktop
Connect pc and screen.
This is new 4 xmas.followed wire connection instructions.pc ,speakers,keyboard all come on with powerlead from pc to wall socket.lcd sreen will not come on.if i take powerlead from pc and put in back of lcd screen comes on.have one lead left over the same connection plug as main powerlead but on other side has not got normal 3 pin plug.this one is smaller one round pin and two flat pins as in a shaver socket and nowhere to plug that in pls advice me ,rgd cloggy this is acer aspire t67 desktop and viewsonic lcd screen
  • wipprecht Dec 27, 2008
    problem right lead now.many thanks,rgd cloggy
  • chris dowell May 11, 2010
    what model number of veiwsonic LCD do you have ?
  • Acer Master
  • 1,102 Answers
The one left over could be for hdmi
your plugging the monitor into the wall and then your other connection into the back of the pc.
did you get a cd for the lcd screen
Posted on Jan 19, 2009
Keyboard replacement
Unplug the laptop's power cord from the wall outlet and remove the internal battery pack. To remove the internal battery pack, simply locate the release button on the bottom of the laptop. This button needs to be held in while the battery pack is slid free from the computer. This button locks the battery in place, so if it is not held in the battery pack will not be able to be removed. Unscrew all of the screws from the bottom of the laptop. All laptops have different amounts of screws holding the external case together; however, there is usually one screw at each corner, and then one or two screws in the center of the laptop. Once all the screws are removed, slide the laptop's hard drive from the computer. The computer's hard drive will generally be located on the left or right side of the laptop; there will be a small symbol engraved into the laptop to denote its location. Remove the screen from the body of the laptop. To do this, remove the two screws from the back of the computer that hold the screen's hinges in place. Once the screws are removed, pull up gently on the screen until the two pegs that held the screen up have cleared the holes in the laptop's body from which they rested. There will be two wires that lead away from the laptop screen so make sure not to pull up so far that they become disconnected. Step 4 Separate the two plastic halves of the laptop's external case to expose the computer's internal components. Lift up on the keyboard pad and flip it on its face. You will notice a film-like strip that leads away from the keyboard and into the heart of the laptop. Before you can remove the keyboard, you must unscrew the metal piece that covers the computer's motherboard. This piece takes up the majority of the inside of the computer, so it will be very obvious to you when you are looking inside the laptop. Disconnect the keyboard connection after the metal covering from Step 4 has been removed. To remove the keyboard, follow the film-like strip back to where it connects to the computer's motherboard. The end of the connection will be held down by a small plastic tab. Pull up on this tab to release the keyboard connector and simply lift the old keyboard out of the laptop. Connect the new keyboard to the laptop. To do this, simply stick the end of the new keyboard's film-like connector inside the plastic tab that you released to remove the old keyboard. Push the tab back down so that it holds the end of the new keyboard's connector in place. Reassemble the computer by putting the components back in the exact spot you removed them from.
Jan 20, 2013 | Computers & Internet
I need a radio wiring diagram for a Holden Commodore LS 1991
Regardless of colour coding, please follow the following instructions (require multimeter):
Note: Attach multimeter earth wire (black) to the vehicle body. Convenient places may be the metal ignition barrel, the vehicle's car arial plug, cigarette socket body etc.
1) Testing for voltage with key out of the ignition, locate the permanent positive wire. This will wire into the yellow wire on your new stereo. The yellow wire circuit powers the stereo's memory.
2) Testing for voltage again. This time you are testing for a wire which only offers power with the ignition turned on. This one will wire into the red wire on your new stereo, and will power the unit only with the ignition on.
3) Now you know which your vehicle's positive wires are you can now test for an earth wire. Switch the multimeter to the resistance setting. There is one setting which will allow a buzzer to sound once you find continuity. With the ignition off test each wire until you get a buzz and a low resistance reading. This should be your earth wire. Double check this with the ignition in the on position. It should remain the same. If it changes to a positive with the ignition on and with the vehicle's lights switched on, then this is the dimmer feed for the stereo's screen. If you unintentionally found the dimmer feed, then you can ignore this wire, and search again for a wire which only offers an earth.
Now you have your power and earth wires located and can wire these into your stereo before continuing.
4) Next you need to use the stereo's balance and fade controls to allow only one speaker output to work from the stereo. So let's start with Left Front speaker output only. turn the stereo volume to mid way so that you can hear when you have connected to the right speaker. bare the remaining wires on the car side and test combinations of the remaining wires until you find the front left speaker of the car. Wire your stereo's wires once you find the correct connections.
5) Repeat the above steps with all remaining wires, remembering to adjust your stereo's balance and fade controls to only allow one speaker output at a time, to ensure the only one possible channel to work and help you identify which of the car's wires power the speaker you have selected.
Before re-assembly of the dash panel, check that your stereo and all functions work properly, being sure to use your fade and balance controls again to test all speakers individually.
If you want to be extra careful and wire the vehicle's speakers positive and negative, according to your stereo's outputs, not that this makes much difference on standard stereo arrangements, then follow this next step:
Make sure you can see the speakers themselves and connect a 1.5 volt AA or AAA battery to the speaker wires. If the speaker's cone pushes forwards, then the wire you connected to the battery's + terminal is indeed the positive wire and should be wired as such. If the speaker does the reverse, then you have the wires the wrong way around. Do not repeat this test for extended periods as damage may be caused to the speaker circuit.
Tip: Always solder all connections and insulate well from each other. Stereo connections can corrode over time and are prone to movement behind the dash. Poor connections may cause faults and low quality sound.
Oct 30, 2012 | Cars & Trucks
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    Can't find to enter code
    Make sure you have selected the correct connect type - wired or wireless.
    Step 3. Let's turn it on and get started! Connect the power adapter into the Roku player and the wall outlet. The Roku player will boot up and display the following sequence of screens:
    • Roku - starting, please wait.
    • Roku - launching home screen.
    • Welcome to the Roku player.
      • Press "OK" to begin.
    • Settings - you will be given 2 options to connect the player to your router:
      • Wired - Ensure one end of the network cable is connected to the network port on the back of the Roku player, and the other to an available port on the home router.
        • Click the "wired" option to continue.
      • Wireless - on the subsequent screens, you will select your wireless network name and enter security password for your wireless network.
        • Click the "wireless" option to continue.
    • Upon successful network connection, the Roku player will then automatically obtain and install the latest software. After the software update the player will reboot.
    Step 4: Let's complete the guided setup!
    Just follow the on-screen instructions.
    • After the restart, you will be asked to select your time zone.
    • Change to your correct time zone then click "done".
    • The next screen will display a unique code to link your Roku player.
    • Open a browser session on a computer.
    • Go to
    • Enter the code displayed on the Roku and TV.
    • Log into Roku account or create a new Roku account to complete linking process.
    Jun 13, 2011 | Computers & Internet
    Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
    Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
    Make the connections as follows
    Hope it helps! Good Luck!
    Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
    I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
    Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
    Jan 07, 2011 | Shuttle AN35N Motherboard
    P4vm800 not working how to solve this probelom
    Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
    1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
    2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
    3. A keyboard.
    4. If your motherboard has no VGA onboard, A good VGA card.
    5. A thumb speaker, or you can use your PC case speaker.
    Okay lets assemble, on a table:
    1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
    2. Connect the pc thumb speaker or your case speaker.
    3. connect the keyboard.
    4. connect the RAM, make sure it clicks as you install it.
    5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
    Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
    Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
    Also check out the PC speaker beeps.
    • 1 beep mean good.
    • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
    • Continous long beeps. cannot detect memory
    • Continous short beeps, motherboard. (or memory sometimes).
    • No beep, fan is this point do everything again. (do it several times until the board responds)
    Hope this helps you. feel free to ask again.
    Oct 14, 2009 | Asrock P4VM800 Motherboard
    I followed the instructions in the manual - but am
    connect your speakers on to the power wall socket and check by touching on the lead which you have to insert into the pc.If you hear some sound then your speakers are ok. after that insert it into the PC.Reinstall the sound driver . I think there is some driver problem
    Jun 23, 2009 | Logitech OEM S220 2.1 Speaker Black...
    Connection between harmon receiver and A-bus in wall speakers...
    There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
    Apr 04, 2009 | Audio Players & Recorders
    Acer Aspire T160 (AST160UA3400) PC Desktop Logo
    61 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
