Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Lamp is new, Push power on and only get green flashing light. Fans are working. No lamp fire up. Opened unit and found all fuses ok. Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual - Need to get another thermistor/device - do you have the part number? On the thermistor/component itself is written: L3 TAM 250V 5A Tf 115c (centigrade) 013 Thanks Tom
  • Anonymous Feb 26, 2009
    shoot we all have the same problem - seems like they made them to break at 7 years
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Posted on May 29, 2007
One has to take the set apart to replace. Do it yourself only if you have the skills and abilities to do basic repair of electronic equipment!
Posted on Jan 25, 2009
I need to do the same. No further posts. can anyone help? How hard is it?
Posted on Jul 02, 2008
I started to have the blinking green power light last night, can you guys show me how to locate/check/replace the thermistor?
Posted on Jan 13, 2008
SOURCE:
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
When I turn the power on all I get is a blinking green power light and nothing else. The lamp is new.
Have you checked the thermal Fuse that is located right above Lamp? These sets had problems
with Thermal Fuse. Is all of the Fans working ? Lamp Fan?
Ballast board is what powers Lamp on. You need to also check 2 thermistors,they are known to be bad.
R2901 (180K-800K)
R2911 (40K-130K)
Jan 13, 2011 | Panasonic PT-40LC12 40" Rear Projection...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Replaced lamp and reset timer, I think as the
It depends on how much the new ballast will cots, new or used that is another question. Do you see any burnt parts, bad capacitors in the ballast board?
Dec 13, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Panasonic PT40LC12 turns on and then shuts off after 15 seconds
Ballast Board it what turns Lamp on Call Encompass Parts Distr. or Look on their website.
Nov 21, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Feb 13, 2008 | Hitachi CP-X327 Multimedia Projector
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
1,239 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
