Question about Sony Cyber-shot DSC-W80 Digital Camera
KEEP SEEING ERORR CODE E:62:11 FLASHING ON SCREEN OF MY DSC-W80
KEEP SEEING ERORR CODE E:62:11 FLASHING ON SCREEN OF DSC-W80 WHAT DOES IT MEAN & HOW TO FIX IT
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    now here is its remedy...
    Check the HALL element (PITCH) of optical image stabilizer (pin 5, 6 of CN402 on the SY-173 board).
    If it is OK, check PITCH angular velocity sensor (SE502 on the SY-173 board) peripheral circuits.
    Its purely technical job and tech person can do it.
    ERROR 62:11 means Lens overheating (PITCH)
    You don't have tools to fix it and its not do-it-yourself job so ask to Sony service center for its repair.
  • 74 Answers
SOURCE: E:62:12
hi there
the error code is teling you that one of the sensors is stuck, you may want to try tapping the camera on both sides and the bottom this useually losens the sensor that is stuck and solves the problem, try tapping it on a table top.
Posted on Nov 03, 2008
SOURCE: Cyber-shot DSC-W80
The camera is probably is "Burst" mode where you hit the picture button and it contineously takes the picture. Hit menu and look to see if you have it set to burst mode if so take it off and it will work..I just found the answer on here :)
Posted on Dec 25, 2007
SOURCE: e:62:12 keeps flashing on my camera
We had the same problem, Sony DSC W80 with the code E 62:12 flashing on the upper right side of the LCD screen. The camera was rotating the photos by 90-degrees. After reading that E 62 was related to the steady shot function, I figured it may be a stuck potentiometer in the camera (it has little sensors that tell the camera what it's orientation is, I guessed one of them was stuck from a "light" fall earlier in the day, while the camera was in the case). I firmly banged the camera in the palm of my hand 3 times on 2 sides... The problem's gone and the pictures are no longer rotating.
Posted on Jul 26, 2008
SOURCE: Sony DSC-T100
Well I can't tell you what E:62:11 means and why it disappears when memory is taken out, however I experienced this same problem with my DSC t-100 but mine did not go away no matter what i did, I looked around online for some solutions I found this one site
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/E.62.10_on_DSC-T9
basically what many people said was the error was probably due to focusing problems if you may have dropped the camera before. On the site they recommended to hit the camera lightly on the side where the battery is located, while the camera is booting up. I did this, and to my surprise IT ACTUALLY WORKED! I couldn't believe it but the error message is gone, and I haven't seen it since. Hope this helps.
Posted on Feb 15, 2009
lock123
  • 6831 Answers
SOURCE: E 62-11 keeps flashing Keeps
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 08, 2010
LENS PROBLEM
Maybe you can take a look to the Sony Cyber-Shot DSC-W80 Manual for finding the answer.
May 01, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
I have a blank screen on DSC-W80 when I try to make a still picture.
Try slapping the camera in the palm of your hand a couple of times. Mine had the same problem and I managed to fix it this way.
Oct 07, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Super Steadyshot DSC W80 and lens keeps going in and out
Hi, Focal lens out of sync. camera cannot initialise. Lens requires manually resetting. If you in the U.K , I can help you out.
p.m me at kiddo242@hotmail.com
Aug 11, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
Jun 16, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
E91-01 error code
You can download user manual of DSC-W80 from Sony Support for free. Check Manuals section.
Thanks.
Jan 26, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
SonyCyberShot DSC W80
If u r unable to see live picture on LCD screen in camera mode, it means CCD Imager of camera isn't working. Contact nearest Sony service shop for proper solution because it requires CCD Imager replacement.
Jun 07, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
E:62:12 keeps flashing on my camera
Jan 28, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Flash not working...
I have a DSC-W80 CyberShot I had a problem with the error code on the LCD Screen that said E:91:01. I played with the camera for a little bit and found the if you push the home button and go to settings. When you get to the settings go to main settings, When you get there go to initalize and follow the instructions. MAKE SURE YOU SAVE YOUR PICTURES OR TAKE THE MEMORY CARD OUT OR YOU WILL LOSE ALL THE PICTURES. I hope this will help you.
Jan 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cyber-shot DSC-W80
Dec 25, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
441 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
