Question about Panasonic PT-AX100U-EC DLP Projector
Heard a pop inside my PT-AX100U followed by smoke out the front
I took it to a repair guy who said the lamp had a short in it so i replaced the lamp. Ive owned it for 2 years seems likely the lamp went bad. With the new lamp installed when i turn the unit on the lamp starts to light up several times then the lamp red indicator light comes on followed shortly by the entire unit powering down. I only see one fuse in the unit and it seems fine. Ive tried the reset also with no change. Ive all ready invested around 600 Euro in this thing since the warranty expired. There was a main board issue after the first year were the unit would turn itself off after some time but that seemed to be remedied after the main board repair. Please help. Larry
  • 33 Answers
Hey I heard This same loud pop well playing games on my Pt-AE700U It was the lamp, once i replaced it i had the saem problem you have to reset the lamp hours on the main screen
Posted on Jun 04, 2009
PT-AX200U Bulb replaced 4 months ago Was on about
carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Apr 09, 2011 | Panasonic PT-AX200U Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My PT-AX100u will not turn on. The lamp is new, I have done the iris fix, which didn't help. When I turn it on, the green light flashes and after 30 seconds, it goes into shutdown mode and then one red...
Yes please call me Just went thru the same issue with my customers projector it involves more then typing can fulfill. Thanks Jordan Thomas
910 538 2754
PORT CITY AV
Nov 22, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
What could be wrong with a Panasonic ax100u with a blinking red light? I am told the lamp might be bad. Could it be something more serious?
if the lamp has been used for more than 1500 hours, then it could be a lmp problem.
1.check the lamp physically for melted filament,cracks etc or white deposits on reflector
2.If yes then lamp for sure is defective
3.if the lamp shows no signs as mentined above than it could be the ballast!
Jan 06, 2009 | Panasonic PT-AX100U-EC DLP Projector
Heard a pop when I started it, now no blower or blinkers
sounds like the ignition switch shorted out like a wire was rubbing and im sure it blew the fuses your going to replace the egnition switch and repair any wire thet is bad and replace the fuse
Nov 14, 2008 | 1992 Dodge Caravan
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Panasonic projector PT-AX100U
lamp blown? if not try this first
worked for me
Oct 09, 2008 | Panasonic PT-AX100U-EC DLP Projector
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-AX100U-EC DLP Projector Logo
261 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
