Question about Video Game Consoles & Games
Wii remotes hte remotes will not sync all the blue lights will come on but will not sync we tried powering off and resetting sync help
  • 4 more comments
  • rrc2006 Dec 26, 2008
    I am trying to use the cooperative game play feature on Prince Caspian for the Wii, but the 2nd controller won't link up - any suggestions?
  • Anonymous Dec 27, 2008
    Wii remote will not work with game
  • karmonz Jan 03, 2009
    cant get the drums to sync. controllers work but drum pad wont work
  • Anonymous Feb 14, 2009
    I have the same problem. the second remote won't connect
  • Anonymous Feb 20, 2009
    i don 't know how to do two player on nba live 09 on the wii
  • mozz2 Mar 01, 2009
    I can operate Topspin3 in single player mode 1 remote but cannot get the other remote to connect for multi players.
  • 48 Answers
Open the front flap on the wii, hold down the red button there for about 3 seconds then take the battery cover off the wii remote & press the red button there too for a few seconds. then press A on wii remote, that should work for you
Posted on Dec 25, 2008
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
Hello, When i try and use the Wii remotes [after charging in the Wii charger dock] all the blue lights at the bottom of the controller flash and then nothing...........also when the controllers are in...
The flashing lights likely means the controllers are not synced to the Wii. Syncing them to the Wii is really easy, luckily
Generally, you can find the sync button under the battery cover on accessories, which should be a small red button. Look around your remote for it.
After you find your sync button on your remote, find the one on the Wii. It is above the SD slot, and you will have to pull open the cover to see it, which is the little rectangular cover on the front of the Wii right underneath the power and reset buttons. The sync button is the little red one.
Once you've found both buttons, hold them both down at the same time for about 3 seconds, then let go and the two should sync with each other. You only need to do this once and you should be fine.
Apr 20, 2011 | Video Game Consoles & Games
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
The batteries went in my wii remote so i replaced them but now cant get the remote to work,,i"ve tried everything i could think of so now asking for your help,can you help please??
You may need to sync up your remotes to your console again.
If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console. Make sure to secure the wrist strap, and have fun!
Nov 24, 2009 | Nintendo Wii Console
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
Remotes not synchronising
Sep 15, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
482 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
DROPNDEAL
DROPNDEAL
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
