Question about GE 46GW947 46" Rear Projection Television
Same Deal-Cricket beeping sound when plugged, Dead TV
I see from other requests that have not been answered that the model GE #46GW947 has the same problem as mine. This is something that needs to be addressed and ask why this problem has not been answered. I need to fix it myself or go to the repair shop with knowledge of what is the problem so I do not get ripped off. Please help me and others with this problem! One day my TV was on and when I left the room it just went out, now there is a soft cricket beeping sound from the back of the set (big screen 36in) when plugged in. I have taken the back off but cannot locate exactly where the sound is coming from. Please help with this as it seems I am not the only one asking about this problem. Thank you in advance for your help, Ksessums
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
I have a guy that wants to give me his 46gw947 because it has no sound but Picture. What could cause this so I know where to start to replace the part that I need. Please E-me directly at cnell9@yahoo.com
Thank you very much!
Posted on Aug 06, 2010
    Novelist:
  • 192 Answers
The chirping sound you hear is normally the regulator circit trying to start up. It needs a signal returning from the high voltage transformer to turn it on. The reason the regulator cicuit is not working varies: The horizontal output is shorted, usually caused by a bad transformer in this model. The focus block goes out in this model quite a bit. The secondary of the power supply may have a missing voltage. I have found that there is no horizontal pulse coming from the drive circuits. Sometimes the regulator circuit itself has an issue. Either way, there are so many problems that can cause the regulator to chirp, diagnostics may be tricky.
Posted on Apr 15, 2007
NO SOUND ON GE 46GW947 TV
Look first to see if the set has the GUIDE PLUS LOGO ON THE FRONT OF THE CABINET OR in the menu, if so unplug set and plug it back to get sound back.
Things to check that are easy, look first:
Does set have sound with a DVD etc connected to a rear input?
Does set have a setting for turning the speakers off or to external speaker hookup?
last might be a actual audio circuit problem but I have never seen that in this model.
Dec 18, 2012 | GE 35GT695 TV
Need new IR Sensor for a GE 46GW947 rear projection. Is this part enterchangeable with any other TV or brand?
ALMOST ANY RCA OR GE MADE AT THE TIME WILL USE A COMPATABLE ONE.
SENSOR IS LOCATED ON TINY PC BOARD IN FRONT OF CRT LENS.
sd tech
May 13, 2011 | GE 46GW947 46" Rear Projection Television
Is there a reset button for the GE 46GW947?
There is NO reset button for this model.
Let me know what problem you have and I will assist you.
If I have helped rate this solution as very helpful as I do this here for you for free.
SD TECH
Aug 17, 2010 | GE 46GW947 46" Rear Projection Television
Tv makes an interval chirp sound when turned on / TV is dead
Ur convergence is dead.The 2 STK convegence ICS are dead.Must know how to solders?Replaced the 2 STK convergence ICS will solved this problems.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | GE 46GW947 46" Rear Projection Television
Projection not functioning properly
this is a common problem in the projection tv faced by many users.that the sound goes out and comes properly when using dvd player on it.but its the problem of weak sound ic on the main board of the tv that has to be replaced its also called the audio ic. as the sound only comes because the dvd itself has its sound ic in the device so the sound comes from that ic which you get.
Mar 02, 2009 | GE 46GW947 46" Rear Projection Television
Convergence option is missing
you have a problem in the deflection board causing the convergence menu to drop out, and the audio out put is causing your problems with audio. You can get parts at this link. Just let them know your model number and they will get back to you quickly.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | GE 46GW947 46" Rear Projection Television
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Need to warm up????
Sounds like something wrong in the tuner circuit How about performing a by-pass test? Use the A/V 1 or 2 inputs on the bottom rear of tv to hook-up signal.Use dvd or source box.When the set is cold,turn on and check.If the pix & sound are good,then the tv has a tuner problem. If you can live with two inputs,no repairs need to be done.Caution:observe funky,side-ways hook-up on A/V 2 !!!
Oct 05, 2007 | GE 46GW947 46" Rear Projection Television
GE 46GW947 46" Rear Projection Television Logo
95 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
