Question about HP Pavilion dv6000z Notebook
Sfc /scannow asks for the xp pro disc to repair the dllcache file
HP dv 5224nr puter Puter works good, but sfc /scannow says that file needs to be repaired for the system to operate properly.
  • 59 Answers
Posted on Dec 25, 2008
Stop c0000135
Probably a deleted or corupted file from a malware removal..
run SFC (System File Checker)
run System File Checker sfc /scannow... For more information on this tool see How To Use Sfc.exe To Repair System Files
NOTE for Vista/WIN 7 users..The command needs to be run from an Elevated Command Prompt.Click Start, typecmd into the Start/Search box,
right-click cmd.exe in the list above and select 'Run as Administrator'
You will need your operating system CD handy.
Open Windows Task pressing CTRL+SHIFT+ESC
Then click File.. then New Task(Run)
In the box that opens type sfc /scannow ......There is a space between c and /
Click OK
Let it run and insert the CD when asked.
Dec 09, 2013 | Computers & Internet
Where can I find this file (cmpnents mediactr i386)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Sep 09, 2012 | Computers & Internet
How do I restore XP rundll32.exe?
I've used SFC to repair Windows 2000/2003 servers in the past, it debuted in Windows 2000 and it fixes system dlls. Start > Run > type 'cmd' and 'sfc /scannow'. You will have to insert a Windows XP SP2 cd for it to work (or mount and ISO of XP with a tool like alcohol 120).
If the %systemroot%\system32\dllcache folder becomes corrupt or unusable, use sfc /scannow, sfc /scanonce, or sfc /scanboot to repair the contents of the Dllcache directory.
Jan 12, 2012 | Toshiba Satellite P105-S9337 Notebook
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
The suspicion of possible errors in the system files in Windows, it may be worth a try to run the "hidden" program that comes with just Windows.
System allows an administrator to scan all protected files to verify their versions.
If System File Checker discovers that a protected file is overwritten, it retrieves the correct version from the cache folder (% Systemroot% \ System32 \ Dllcache) or source files for Windows installation, and replaces the incorrect file.
System File Checker also checks and filling up the cache folder. You must be logged on as an administrator or a member of the Administrators group to run System File Checker.
If the cache folder becomes damaged or unusable, you can use the sfc / scannow, sfc / Scanonce or sfc / scan boot to repair its contents.
To use SFC:
1) Press Start
2) Select Run ...
3) Enter: sfc / scannow and press OK
you should find the windows cd and put itin the cd player on the PC, if you have some corrupted system files so the process will bring it from cd to the computer
Sep 09, 2010 | HP Computers & Internet
Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Feb 14, 2009 | Microsoft Windows XP Professional
How to get Recovery Discs for refurbished Gateway MT3705
If the computer has the same version of xp on it that the disk has,Just restart in safe mode,Select safe mode with command prompt,When it get to the command prompt,Put the xp disk in and type
SFC /scannow
This command will immediately initiate the Windows File Protection service to scan all protected files and verify their integrity, replacing any files with which it finds a problem.
Windows XP keeps a cache (copy) of these essential files at the following location:
But it still may ask for the disk.
Please rate this a fixya
Feb 14, 2009 | Gateway MT3705 Notebook
Click here, select your operating system and download the software and drivers, then see if it works you may just have a bad disc.
Good luck,
Jun 14, 2008 | Kodak EasyShare C613 Digital Camera
HP Pavilion dv6000z Notebook Logo
626 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
