Question about NetGear WNR854T Router (WNR854T100NAS)
Power light only, no network availability.
Ok, I know a lot of other people have been getting this problem and the suggested route is to go back to Netgear. But I not long ago bought this second hand for £80 and so the warrant will have run out and I have no intention of having to buy a new one. So someone out there must know what the specific problem is and how to physically repair it, what part needs replacing, etc.
The symptoms are, the power light comes on but that is it and no connectivity occurs.
Hope someone out there can help out
Cheers
Sean
  • Sean Cole
    Sean Cole Dec 26, 2008
    Thanks Dipu007 for the fast reply.
    I've noticed that you give the same advice to loads of others too but it doesn't work. There is a more serious problem with the hardware on these devices. I know you have to assume I'm an idiot but I am not - I'm a qualified service tech for loads of appliances so generally know what I'm doing.
    Just to reinforce what the problem is - It comes up with a power light but doesn't flash amber (to show it's doing the self test) and so goes no further. This is not a wireless problem either just in case you are tempted to say 'there are a lot of problems with it's wireless chips' - This is not the problem!! It's not even starting the self test so it is something more basic than that.
    Looking forward to more than a 2 line response!
    Cheers
    Sean
    President:
  • 2,110 Answers
Reset to defaults and start over.
It's possible your router is dead.
Posted on Dec 26, 2008
Disable network password
do you get any error messages? open cmd from another computer and ping the pc in question (assuming this pc gets an ip). if "ping" works then try net view \\computer name or ip. you should be able to see the shares or get an access denied usually 5.
Try that and let me know what you got so that i might understand the root of the problem.
Jul 13, 2014 | Computers & Internet
Trying to connect wireless router so we can have access to x box live
Go to network sharing and turn network discovery on make it a private network and then go to windows media player go to bottom of library click on media sharing click share your media it should show your XBOX and if doesnt have a green check on it click on xbox and then click allow sharing. If this doesnt work I can walk you thru let me know and we will have to go another route to get it working for you but talk you through it on here. I need to know computer operating system, is the wireless network working with your computer, version of media player, and steps you have taken so far and go from there. I will be available for the next few hours so if you respond I will get back to you ASAP..
Stormi
Nov 16, 2010 | Microsoft Wireless Network Adapter Xbox...
Please Help! I THINK I have a bad power supply (a bestec atx-300-12eb3 rev s2 from a Sony Vaio VGC-RB30). Power will no longer come on at all, however I do have a blinking green light on the back of the...
ok first you disconnect the power supply from motherboard then measure the output voltage if it is ok then there is two wires green and black at o/p of power supply short green and black and see fan is rotating or not if rotating then power supply is ok if not then open the power supply check ac voltage in the pcb if present then check dc voltage after bridge rectifier and ckeck part by part
Feb 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Swapping MacBook Screens
As long as the lcd cable connects to the new screen it should work just fine. Just power it on before putting all the screws back to make sure.
In regards to the wireless I don't understand the question completely. The 2006 will probably only have two wires...just make sure they go where the white and black ones did. You'll just lose a lot of the "N" network strength.
Hopefully that answers you questions. If not, let me know.
--RescueTechLA
Nov 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
What do I need and what do and what do i need for hook up
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. T
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.1.1or http://192.168.2.1 or 192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". or username admi password 1234
username: admin password: admin
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
follow the wizard
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Aug 08, 2009 | Computers & Internet
My wired connections all work fine but my wireless conection wont work ive tried everything i know its been like this for 3 months now i dont know what to do
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
5. Power cycle.
Jul 08, 2009 | NetGear WGT624 Wireless Router
Can not connect netgear wireless to mini laptop
Since your Internet Service Provider is using a cable connection, please follow the steps below:
5. Power cycle.
Mar 13, 2009 | NetGear WGR614 Wireless Router
Passphrase
ok....
it seems that you are tring to connect to someone elses secured network which means you will not be able to connect to this wireless network as it has security enabled in it and the passphrase is know to the person who has setup this network....what i can suggest is that you can try connecting to unsecured networks if it is available...if there is no networks unsecured networks available then you will not be able to connect to the internet wirelessly..
vedhick...
Feb 07, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Drawing
This happened to me twice, and both times were after I had downloaded a long route. Both times, the only available fix was to do a "hard reboot" by selecting page-OK-power and then selecting "yes". That restored operation, but it also deleted the downloaded maps, routes, and waypoints, and forgot my preselected options.
(In MapSource, I had used the "Select maps around route" option, and both times the total memory associated with the selected maps was much less than 115MB - one was 59MB and the other was 63MB. And in three years this has never happened when fewer maps were loaded. My experiences therefore suggest that the actual working memory available for downloading is much less than 115MB - I don't yet know what the actual limit is.)
May 24, 2008 | Garmin Quest GPS Receiver
NetGear WNR854T Router (WNR854T100NAS) Logo
50 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
