Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Convergence not lining up
I have had a problem with a green tent on every channel. It is most evident with white text on the screen. Green color will separate from the white text, separates to the right only. On HD channels, the color red will separate and follow the outline of someone's nose or head or arm. On the convergance screen the red and blue line up fine. The vertical green will line up fine with both red and blue. The horizontal green is about a centemter longer than the blue and red causing the white horizontal line to have a green tail. If I move the blue and red to line up with the right side of the green then the left side will have a centemeter of green and the vertical green will be separated from the red and blue. The best I can do is a nice white cross with a centemter of green exposed on the end of the right side of the horizontal line. I have had the green projection tube replaced and 2 internal chips replaced. (I do not know the names of the chips replaced.) The problem has not been fixed and they do not know what else to try. Any advise would be appriciated. I am a little frustrated with the repair shops not knowing what to do for me. thanks...
  • Chad Russo Apr 16, 2007
    That did the trick. My tv is back to normal. Thanks for the help.
    Novelist:
  • 192 Answers
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Posted on Apr 15, 2007
SOURCE:
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
    Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
    Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
    According to the manual:
    1) go to the "TV Main Menu"
    2) Select "Screen"
    3) Select Adjust Projection TV (obviously only if a projection TV).
    This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
    Good Luck!
    Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
    Color is seperated
    Your TV most likely has a Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
    The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
    Mar 15, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
    Double Image Red and Green
    • Screen looks 3D
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    2c07611.pngSolution
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
    Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
    Red green and blue lines rca 52' rear proj.
    your convergence powert supply is not working-
    replace the supply or repair it
    Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
    Sounds like a convergence promblem.
    Here are some of the most common symptoms of a convergence problem.
    Screen looks 3D
    Screen is bowed in or warped.
    Using your original remote go-to the tv settings then goto the convergence or magic focus section.
    Try to adjust the convergence.
    Its a fairly easy fix on the Hitachi sets.
    You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
    Everything you need to fix it yourself.
    Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
    Hitachi 61SDX01B
    The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
    accurate because the red and blue convergence overlays on
    the green.If you have more than an alignment issue,that will need
    repair before adjustments are attempted.
    Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
    412 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
