Question about Philips VOIP3212 IP Wireless Phone
The base isn't recognized.
My base indicated that USB is conected, but i didn,t plug at my computer. When I plug, the windows vista can't find anything. Can somebody help me?
    Problem Solver:
  • 4 Answers
Here we are again. Download the driver from the Philips web site and NOT the CD. This will sort it. I had exactly the same problem
Dave B
Posted on Dec 30, 2008
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
Hi, I can't get my scanner conected, it was conected, turned it off ,now can't get it to work. ion PIC2pc. Thanks Nan
Hello.
Be certain that you followed the step-by-step instructions (From ION Support):
1. Turn on the computer.
2. Insert the installation CD into the CDROM
drive and the installation menu will appear. *
3. When you see the installation menu, click Install Driver.
4. Follow the on-screen instructions.
5. When the driver installation is complete, click BlazePhoto to install the software.
6. Follow the on-screen instructions.
7. If your computer does not have DirectX 9.0 or greater or Adobe Reader, click those items to install them. (If your
computer is using Windows XP Service Pack 2 or higher, Windows Vista, or Windows XP Professional, this is not
necessary.)
8. Click Exit to close the window.
Note: The first time you connect PICS 2 PC to your computer, wait a few seconds until you see a dialog box
that says "Found New Hardware" (this means the computer recognizes the PICS 2 PC). After you see this,
PICS 2 PC is ready to use.
If you followed the above instruction and still have a problem, reinstall (first, Remove from Add/Remove Programs) the software and be certain that the USB cable is snug.
If your computer is not recognizing the ION PIC2, be certain that your computer has a USB 2.0 port. Check your Device Manager to verify what USB port.
If still a problem, what error message(s) are you getting ? What operating system software (Vista, Windows 7, etc.) ?
Hope this helps.
Jun 28, 2011 | Office Equipment & Supplies
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
Motorola VE 440 computer does not recognize when connected w/USB
you might want to try it with a computer running Windows Vista - older operating systems will generally tell you that something is plugged into the USB port but will not allow you to access it as it does not recognize new software.
Mar 19, 2010 | Cell Phones
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Magellan Maestro 4000
hi scott,
i might not understand what your asking, but if vista is listing the tfat and the sd card slot, then it is being recognized...thats what its suppose to do.
with the gps on and booted, once you plug in the usb cord, the hardware wizard should pop up and install it, then youll see it listed as tfat in your computer.
if im missing your ? please post back so i can help you further.
bill
Nov 20, 2007 | Magellan RoadMate 3050T GPS Receiver
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Philips VOIP3212 IP Wireless Phone Logo
259 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
